Transmission overheat?
    The color of the tranny fluid is important too. If it's not dark, that's a good sign.
    Please do let us know what's up with the rear end. I don't think I've heard of such a problem before.
      Im curious as well, the 8.8 is nearly bulletproof.
        I'm going with the axle sheared at the outer bearing and the wheel is being held on by the brake caliper.
          That sounds oddly familiar.
