On boxes, anything to be gained from a ( more flow) pump? With or without upgrades?
high volume oil pump
For a good small block Ford: IMO nothing gained, a few horsepower lost.
IMO Stock volume and pressure are fine.
If the tolerances are on the loose side and you are having oil pressure problems, a high volume will mask the problem. I’ve seen people do this with OBS Ford trucks before selling them.1990 Country Squire - weekend cruiser, next project
the other problem with high volume pumps in old nasty motors with not so awesome oil returns is they can actually put enough oil in the top of the engine that it runs the sump low. The drains have to be in pretty bad shape for that to happen though.
Otherwise, no point unless the motor is sloppy enough that it doesn't make oil pressure, and really that isn't the way to fix that problem correctly anyway. it will serve as a band-aid though.86 Lincoln Town Car (Galactica).
