Anyone have a link for a set of headers on a 302 (1985 Carb) that will bolt up without any problems, thanks for the help
Headers
If you are making no other changes to the exhaust, there is no spoon. The collectors on the manifolds are smaller than any of the headers and its not going to fit. If you're OK with having the flanges on the downpipes replaced with larger ones, then any shorty header for a Fox mustang fits fine.86 Lincoln Town Car (Galactica).
The one alternative some go with is finding lincoln logs from a 1990 Town Car.
They are slightly less manifold looking and more header looking. They will also bolt directly up to your stock h pipe/cats.~David~
Originally posted by 1985crownvicltd85 View Postthats a good idea and I like the look of them, I found some on rockauto and it looks like the o2 sensor holes are blocked off, hopefully it is because I obviously dont need them.
Those are the normal cast iron lumps they installed on everything else.
I don’t have any good pictures, and photobucket ruined everything here.
The real ‘90 LTC units are tubular and flow a bit better. Your only source is going to be used ones though.
When installing aftermarket headers, what can one do about the 02 sensor that connects into the passenger side exhaust manifold? Most aftermarket headers don't have an 02 sensor bung in that location.1985 2-Door: CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, ASP Underdrive Crank Pulley, Bilstein Rear Shocks, Rear Lowering Springs, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Ford Racing 4.10 Gear, Eaton LSD Differential - I own the fastest CFI powered box to the 1/8th mile: 9.658@70.74mph
1991 4-Door (Dad's Car): Pro-M EFI, 306ci, Forged Pistons, Ford Racing Aluminum Heads, COMP XE264HR cam, Cobra 1.7 Rockers, Edelbrock Performer RPM 2 Intake, 30lb. Injectors, Custom 65mm TB/EGR Spacer, Pro-M 75mm MAF, BBK Ceramic Shorties, Custom Summit H-pipe, Walker Mufflers, Jegs Built AOD, Roadrunner 3000 Stall Converter, Ford Racing 4.10 Gear - Best 1/8th mile time: 9.76@72.03
Originally posted by sluggish91 View PostWhen installing aftermarket headers, what can one do about the 02 sensor that connects into the passenger side exhaust manifold? Most aftermarket headers don't have an 02 sensor bung in that location.
add a new bunghole.86 Lincoln Town Car (Galactica).
