do the boxes have 2 flashers? turn and hazard?
    If they do where is the hazard unit and what does it look like?
    Yes. The hazard is on the back side of the fuse panel, looks just like the regular one.
      That explains it.
        Some of the flashes have a different value. Could flash faster or slower depending. And one or both of them may be plastic instead of metal.
        Also take mental note of the orientation when you remove the backside one.. can be a bitch to get it back in sometimes. The fuse panel plastic may crack on you depending on condition. Forwarning
        Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
          Weird i didn't know this. Had to change my flasher when i put in new LED taillight bulbs but the hazards still work normally. Huh, learn something new every day...
            My hazard flasher stopped flashing after converting to LEDs so I had to replace both.
              knucklehead did you change front and rear? Also if i understand correctly some bulbs have resistance built in, defeating some of the reason for having leds.
                I retain standard bulbs so I can keep the original bi-metal flashers. They make the right noise. I actually rolled several through the Continental to get one that produced the right flash rate and tone.
