Results 1 to 8 of 8
Thread: do the boxes have 2 flashers? turn and hazard?
    Dec 2011
    Yonkers NY
    4,157
    Default do the boxes have 2 flashers? turn and hazard?
    If they do where is the hazard unit and what does it look like?
    39,356
    Yes. The hazard is on the back side of the fuse panel, looks just like the regular one.
    Dec 2011
    Yonkers NY
    4,157
    That explains it.
    Mar 2013
    New Haven, Indiana
    1,254
    Some of the flashes have a different value. Could flash faster or slower depending. And one or both of them may be plastic instead of metal.
    Also take mental note of the orientation when you remove the backside one.. can be a bitch to get it back in sometimes. The fuse panel plastic may crack on you depending on condition. Forwarning
    Apr 2015
    Southern Commiefornia
    2,345
    Weird i didn't know this. Had to change my flasher when i put in new LED taillight bulbs but the hazards still work normally. Huh, learn something new every day...
    Jan 2007
    Westmont, New Jersey
    10,378
    My hazard flasher stopped flashing after converting to LEDs so I had to replace both.
    Dec 2011
    Yonkers NY
    4,157
    knucklehead did you change front and rear? Also if i understand correctly some bulbs have resistance built in, defeating some of the reason for having leds.
    39,356
    I retain standard bulbs so I can keep the original bi-metal flashers. They make the right noise. I actually rolled several through the Continental to get one that produced the right flash rate and tone.
