Results 1 to 13 of 13
Thread: Brake hoses.
    Default Brake hoses.
    I'm getting stainless braided brake hoses made for my 97 MGM. Apart from the hoses going to the calipers. Are there any other rubber brake hoses on the car? I see on Rick auto that they have a "Center" brake hoses. I couldn't find anything under the car unless it's really hidden.
    Any insight? Thanks.
    Stow It! GM_Guy's Avatar
    Ontario, Canada
    3,274
    That'd be the brake hose to the rear brakes. Look at the transistion point from body to axle.
    At the rear of the car? The hoses go from the body straight to the calipers. They don't go on the axle than the calipers.
    Dec 2011
    Yonkers NY
    4,030
    ABS vs. non ABS
    I have ABS
    38,502
    None of the rear disc brake cars have the center hose. They all have a hose that runs from the caliper up to the hard line in the wheel well area. The drum brake cars from the 80s have a center hose over the axle and steel lines from the center top of the diff out to the wheel cylinders.
    The difference between ABS and non-ABS is the hoses on the driver's side. ABS has only one hard line connection, non-ABS has 2. Passenger side are all single connection.
    If down the line I want to upgrade to 1998 front calipers. Do I need new front brake hoses?
    38,502
    it says 98-02 on the hoses, but I know people have bolted 80s hoses to the 98-02 calipers. Looks like the 98-02 hoses have a steel L section at the caliper end where the 95-97 ones do not. Possible it will bolt up and function, or the hose might turn into a steering stop and rip apart at full lock. Don't honestly know. My 86 with the big brakes runs 98-02 hoses.
    I post a lot... Toploader's Avatar
    May 2013
    1,736
    Make sure the hoses have a protect coating around the ss as mandated by law....could be PVC or some other material.
    The line going from the master cylinder to the ABS Module has an uncovered section of stainless braided hose. It's in good shape, just uncovered.
    Member Donal's Avatar
    Jan 2011
    Sidney, Ohio
    111
    I have a 1993 Grand Marquis. I need to replace the hose at the drivers side rear, near the wheel. I don't remember if I have drum or disc brakes on the rear The hose has a two line connection fitting. This means I do not have ABS? The guy at the parts store wanted to know if I had ABS or anti lock and I did not know what to tell him. Are ABS and anti lock the same thing?
    1993 Mercury Grand Marquis 4.6L AODE[SIGPIC]
    Quote Originally Posted by Donal View Post
    ABS stands for anti-lock braking system, you should have just told the part guy your question. Do you know how to flush/bleed a brake system after replacing the hose?
    38,502
    92+ all had disc.
    and yeah, ABS = Antilock Brake. If its a hose with 2 metal lines screwed into it, you do not have ABS.
    if one hose is bad, I'd probably replace the other one too. They've been on there the same amount of time. Me being me, I'd more likely do all 4, they're old enough at this point to justify it.
