Results 1 to 3 of 3
Thread: Blower motor switch location 1990 CP
  1. #1
    Default Blower motor switch location 1990 CP
    My fan only blows on 3 speeds. The HI speed don't blow at all.
    Where is the blower motor resistor switch located at?
  2. #2
    39,275
    The switch is the fan speed control in the dash. The resistor lives behind the valve cover on the passenger side. the resistor is bypassed in hi though, so either the connection is crusty or the switch is dead on hi.
  3. #3
    Thank you Gadget.
    I did find it. It's under the heater hoses.
    I'll look into the crusty connector this weekend.
    Always thank you for all of your help.
