I just purchased an '89 Grand Marquis a few days ago and I'm having a problem with LED headlights that were installed. When I pull the headlight switch, none of the headlights come on but all other lights work. If I fully engaged the high beam lever, the two outside lights come on, but all of the LEDs (15) in each are lit. If I just flash the high beam lever, all four lights come on with all of the LEDs in each lit. I assume it's just a wiring issue, but I'm not sure what exactly.
Issue with LED headlights installed by previous owner
May need to repin your connector to H4 specs, if that’s what your LED bulb wants.1990 Country Squire - under restoration
i f that doesnt work, sealed beams aren't that spendy86 Lincoln Town Car (Galactica).
Originally posted by Tiggie View PostMay need to repin your connector to H4 specs, if that’s what your LED bulb wants.
Sounds like you may have swapped the wrong two pins.
Do you get any power at the connectors when the headlight switch is on but the high beam lever is off? If so at least you then will know which is the low beam hot wire,03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
the green wire is high beam, red is low, black is ground. In stock form the green wire goes to both inner and outer lamps, the red goes to the inner only.
