Page 1 of 4 123 ... LastLast
Results 1 to 20 of 70
Thread: 351W Build
    Jan 2008
    New Jersey
    3,071
    Default 351W Build
    So my original 351W is starting to knock when cold. As a result I've decided to begin building a higher performance replacement. I've already bought a roller 351 out of a 96 pickup. I need to take the cam bearings out and check to see if it has the journal cracks- either way I'll be going roller.
    So my current plan is to have the shortblock rebuilt with stock pistons, throw some Trick Flow TW 170's on there (supposed to be equivalent to AFR 185's), have my Edelbrock Performer 4 barrel intake (with EGR, a rare beast) professionally ported by "Tmoss", throw in a custom cam, and put a Holley Sniper self learning fuel injection unit on it.
    The goal is to have it smooth and very streetable, work on 87 pump gas, while making the most amount of power with those exceptions.
    If anyone has suggestions to help improve my build please chime in! Especially about other heads and cams. I know some people will say the heads are too small for the engine, however that seems to be coming from drag racers posting online.
    Member Grand1's Avatar
    Feb 2012
    Michigan
    649
    I am starting to collect parts for my 87 rebuild. HAVE to replace the oil pump....so the whole damn engine needs to come out anyway. I am goona stick with the hydro flat tappet. Been looking at these heads seems like it is a possiblity. From what I have heard, GT40 heads really dont do that much.
    https://www.speedwaymotors.com/Flo-T...ead,46332.html
    This cam
    https://www.lunatipower.com/barebone...o-270-280.html
    1987 LTD Crown Vic 351w aka the "MI Mountie"
    1979 Marquis creamy goodness
    40,025
    Any reason you're keeping the EGR?
    enormous heads don't make for wonderfully streetable motors. If it sucks under 3000 rpm, thats just not useful.
    Jan 2008
    New Jersey
    3,071
    I went from stock D8 heads to gt40s, definitely a power increase, but nothing to write home about, even after upgrading it to a 4 barrel.
    I’m sure those flo teks will perform decently, my only concern is who knows how many miles they’ll last though compared to one of the higher budget heads
    When I yanked my trick flows off the maverick and took them to the machine shop they were still like new- needed nothing. I was very impressed.
    Love me EGR- lower combustion temps at cruise, higher timing potential during cruise, less NOX emissions, potential for slightly better mpgs ... There’s no reason not to keep it- especially since I already have the intake and system running it. Even if I get another intake- id still have to have it ported. They don’t make very good performance carb intakes for the 351w when mater with aluminum heads
    Jun 2006
    Holland,MI
    518
    FYI: These are those journal cracks he referenced.
    https://forums.corral.net/forums/5-0...lock-guys.html
    You will probably need the small CC version of any head because of the stock style pistons have those huge reverse domes. And they will probably still be .025" in the hole if you're not decking the block beyond a clean up.
    Not sure any of those throttle body efi rigs can handle a EGR system either, so you may not be able to use it.
    351W & F.A.S.T equipped
    Aug 2010
    Moore, SC
    479
    That’s the first time I’ve heard of anyone touting their EGR system! Lol. To me the benefits are greatly overshadowed by one drawback...they turn the intake into an oven. I wouldn’t bother with spending money on go-fast parts just to negate the benefits by jamming super-heated air through them. Hot air is not dense air and dense air is where the power is. Just my $0.02.
    GMN Regular clutch47's Avatar
    Apr 2019
    855
    You plan on a custom cam. Good call. Do you mean one made specifically for your build.?
    All FORD All The Time
    Told ya everything I know when I said hello P72Ford's Avatar
    Feb 2007
    In the 860
    7,204
    Unless you have the TW170s, go with the 170 11R. I'd actually go with the 190 11R (same money at the 170), despite your modest goals here.
    Roller cam and link bars.
    **2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 17K Cruiser
    **2006 MGM,"Ultimate": 4.6/ 2.73/ Dark Tint, 76K Daily Driver
    **2012 Harley Davidson Wide Glide (FXDWG):103/ Cobra Speedsters/ Cosmetics, 7K Poseur HD Rider
    **2014 Ram 1500 QCSB Express: 4WD Hemi/ 8spd TF/ 3L21/ Exhaust/ Cosmetics, 39K Truck Duties
    Jan 2008
    New Jersey
    3,071
    Other people who have asked are told by holley the sniper system wont work with EGR...bummer.
    Yes a custom ground cam for my build. Might as well get out of it exactly what I want. Recommendations of companies welcome!
    The 190's will require different pistons, or I would consider them. The 11R's seem nice, but are a decent chunk more $$ than the regular twisted wedge pieces. The block is already a roller, so it'll be getting a roller cam, any particular reason for the link bars?
    22,062
    Linkbars or dog bones help to stabilize the rollers and keep them from spinning in the hole and destroying the cam.
    Jan 2008
    New Jersey
    3,071
    Ahh the dog bones- of course, they come stock with the lifters in this case. I wasn’t as familiar with the linked lifters
    Feb 2007
    In the 860
    7,204
    I thought you were using the original engine, and would be retrofitting a roller grind, only reason I suggested link bars.
    Nov 2006
    Dirty Jersey Yo!
    8,236
    Thumbs up
    Jim Woods @ FordStrokers.com does custom grinds
    Ed Curtis @ FTI cams is said to grind good cams
    Those are the 2 custom cam grinders I looked into when I was considering a cam.
    In any event; can't wait to see what you come up with.
    Feb 2012
    Michigan
    649
    Was looking at this....you get alot for $880.
    https://www.ebay.com/itm/fits-Ford-3...4383.l4275.c10
    Apr 2015
    Southern Commiefornia
    2,352
    Definitely get a cam from Ed @ FTI, he takes into account all your specifics and power goals. If needed, he'll also provide matched components like valve springs, etc, that are precisely meant to work with your setup and the cam he grinds for you. As for the heads, if you didn't already have the TFS i'd suggest AFR's for sure, and even 165's would be fine on a mild 351, and make a shitload of torque. Watch the episode of Engine Masters where they test 3 different AFR heads on a 408 windsor. They test 165, 195, and i think 205. Of course the 205 makes the most power but they all marvel at the glorious torque/power curve that big motor makes with the small heads. It's pretty impressive. Having acquired a set of 165s, i really wanted to put them on my 347 but it's already set up for the edelbrocks and i reckon they're on it now so i'm just going with it. Really wanna put those heads on something, just need to find the right victim.
    Far as the egr crap goes, if you don't have to, i wouldn't use it, and run a better intake like an RPM air gap. Kudos on the EFI plan though, i've been toying with something like that on a future project, seems a great setup.
    Jan 2008
    New Jersey
    3,071
    I was actually looking at ED Curtis for the custom cam.
    As this build is currently still fluid, i've decided to go with the Trick Flow 190 11R's. They are pretty amazing, and they do not require different pistons (i thought they did) despite their massive 2.05 intake valves.
    The RPM air gap looks sweet- im going to keep my eye out for a used one. If not i'll just get a performer RPM when one pops up used. I will most likely still want to get it ported to match the heads though
    Apr 2019
    855
    You could give this place a call. Open 50+ years and they've always treated me right.
    https://www.midwayperformance.com/predatorcams/
    We'll be dynoing a 393 Cleveland for me this week. I'm hoping it does around 600 HP and 500 Tq.
    Apr 2015
    2,352
    I think summit or pro-products has a knockoff of the RPM air gap that's probably a bunch cheaper and flows almost as good.
    Jan 2008
    New Jersey
    3,071
    A few more thoughts- Supporting mods.
    Rear is a rebuilt 8.8 with trac-lok, driveshaft is a new police aluminum unit. Im not really worried about these. However if the more experienced guru's out there thing a support cover/girdle for the 8.8 is necessary i may get one.
    Transmission. stock 82 unit with 86 valve body and Baughmann shift kit. I would probably be worried about grenading this...however my stock truck tires don't exactly scream traction. I think they will spin far before ruining the transmission. Im also not planning on drag racing it. Thoughts?
    Anything else anyone can think of that im missing here? I would ideally like to upgrade the brakes, but that's not happening right now with my current wheels. I have performance pads that have resisted fade nicely so far.
    40,025
    Thats the weakest of the AOD's, so I wouldn't trust that it will hold up. You can get a bit more out of it if you upgrade the overdrive servo, but the later cases had some extra lube passages that help things survive. If you can lay your hands on a later transmission, even to use as a future core, it would be worth doing. Generally the 89+ case is considered to be the best.
    You can do a 95-97 upgrade. They're somewhat larger and most of the way to the 98-02 brakes should you want to change the wheels later. I'd probably really only consider this if you were planning on doing a suspension overhaul anyway.
