Page 3 of 3 FirstFirst 123
Results 41 to 52 of 52
Thread: 351W Build
  1. #41
    39,926
    I think '80 or '81 was the end of the C4 in these. They weren't around for very long.
  2. #42
    GooGooG'Joob Quincy's Avatar
    Dec 2020
    Southeast USA
    140
    Oh yeah, that's right, I've read that in various places. Brain fart! I'll probably be keeping mine for the time being anyhow. I certainly wouldn't switch to a C4 if it wasn't already so-equipped!
  3. #43
    Member
    Jun 2006
    Holland,MI
    503
    My 79 tudor had a case fill c4, a 79 parts wagon I have has a pan fill c4 w/ 351w. No idea if it is originally that or not.
    When I took the jasper rebuilt 302 from the tudor to do mild H/C/I and put in a 84 wagon with an AOD I had to use the C4 flex plate with the AOD because it was a 28oz motor not a 50oz motor like I pulled from the 84.
  4. #44
    39,926
    oh yeah, early block vs late block balance change.
    I'm really not much for 3 speeds. Either its screaming on the highway or it sucks off the line. Or its kind of lousy in both conditions. 2 speeds are even worse, though they're just terrible all the time. More than 6 speeds and it seems like the transmission never stops shifting though, so there is a happy number of gears where things work well without being annoying.
  5. #45
    Jan 2008
    New Jersey
    3,040
    Progress!
    I got the cam, timing chain, lifters+retainer, 1 head, rocker studs, and rockers installed. I also checked/degreed the cam. Everything was spot on so no adjustments needed. Next I'll be measuring pushrod length. Once I get the pushrods i can check PTV clearance (which I'm not worried about based on others experience with far more radical setups than mine).
    It will be a sin to put these rockers under a valve cover
ID:	55613Click image for larger version.
ID:	55614Click image for larger version.
ID:	55615Click image for larger version.
    -Phil
    +1982 Ford LTD-S Police Car. 351w, GT40 Heads, Edelbrock 1906 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. Speedway Springs+Bilstein Shocks, Intermediate Brakes, Baumann Shift kit.
  6. #46
    39,926
    wad of clay and an engine rotation is cheap peace of mind tho. Mostly its long duration cams that will cause you problems, not so much total lift. The valves are closing as the piston is coming up the bore.
  7. #47
    Mar 2006
    Bedford, VA
    6,063
    Very good. Glad you used the degree wheel to check. Don’t make my mistake!
  8. #48
    Jan 2008
    New Jersey
    3,040
    Don’t worry Gadget, I’ll definitely check it!
    Tiggie- it’s always easy to make a mistake like that, plus you never know if the timing gear factory had a bad day with is machinery, or the custom cam was ground wrong! Kind of an expensive way to check, but now I have a dial indicator for other projects
    -Phil
  9. #49
    39,926
    I've never actually used a degree wheel, though I probably should have when I changed the cam in my car. Then again I also wasn't 100% sure the valve springs or the p2v clearance was going to be OK. basically I stuck it together, cranked the engine over by hand and sent it when nothing went "bonk".
  10. #50
    Sep 2008
    Whitestone, NY
    19,772
    I bought a degree wheel kit for my engine build...read the instructions and just didn't bother. Its somewhere in the garage for future use.
  11. #51
    Jan 2008
    New Jersey
    3,040
    Got my pushrods measured. The Intake and exhaust are slightly different sizes. Triple checked in all different ways. Seems most places are out of trick flow or comp cam pushrods. Going to give this company a try: https://www.pushrods.net/one-piece-pushrods
    -Phil
  12. #52
    39,926
    just make sure they use the same measurement system. I made my own adjustable that measured total length and found out that Comp's measuring system is from the centerline of the ball end, not end to end like you'd get from a caliper. There was only a few thousandths difference among the 16 valves, not enough to matter. Amusingly the new pushrods were the inconsistent part, longest to shortest was about .020 different and I have different shims under each rocker depending on what specific pushrod went in there. If I ever pull them out I will have to lay them out to go back in the same hole. The factory rods were much more consistent.
    if yours is consistently different I to E I'd guess the valve stem lengths aren't the same. Could probably lay a straight edge across them and see that.
