Page 4 of 4 FirstFirst ... 234
Results 61 to 70 of 70
Thread: 351W Build
  1. #61
    P72 Interceptor
    Dec 2009
    Wichita Kansas
    122
    The program is called Camquest and according to Comp Cam's website is currently down for maintenance and updating. Sorry I didn't realize.
    Internal combustion of all types is a mechanical symphony, but it is the primordial roar of a V-8 that stirs a man's savage soul.
  2. #62
    40,020
    Intake to core, core to water pump. Restriction needs to be on the side coming from the intake. If the thread size didn't change, I don't see why that part wouldn't get the job done.
  3. #63
    Sep 2008
    Whitestone, NY
    19,892
    That is a trick looking piece. Keep the little bit of excess pressure in the engine and not in your hose as compared to the more traditional restrictors.
  4. #64
    Jan 2008
    New Jersey
    3,070
    Thanks guys
    Another technical question: Engine Oil Cooler. I have the stock one but a lot of sources online say they can do more harm than good on a street car. With todays synthetic oils it makes it even less necessary. It's cool to have, but also a fail/leak point. Should I delete it?
    -Phil
    +1982 Ford LTD-S Police Car. 351w, GT40 Heads, Edelbrock 1906 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. Speedway Springs+Bilstein Shocks, Intermediate Brakes, Baumann Shift kit.
  5. #65
    Mar 2010
    Lewisville, TX
    22,061
    If you get your engine up to temp when driving around and do the occasional 20+ minute romps after warming up to burn off any condensation that's built up, then you shouldn't have any issues. Doing a quick run somewhere that takes about 15 minutes to get there and not staying long enough for the engine to cool off and driving home will also probably be enough. It only really comes into play when your normal drive is under 10 minutes as there's not really enough time to get up to temp properly, oil cooler or not.
  6. #66
    40,020
  7. #67
    Mar 2010
    Lewisville, TX
    22,061
    ooOOOoo
    Nice.
  8. #68
    Jan 2008
    New Jersey
    3,070
    That’s not a bad idea! I’m not sure how I feel about adding another thing that could potentially fail.. I’ll have to think on it
    A couple other thoughts- some sort of WOT A/C cutout seems a good idea. I’d like a switch that simply used a low vacuum signal to open the circuit, but I can’t seem to find something like that... EDIT: check this out: https://www.ebay.com/itm/Adjustable-...pid=1322982828 or this
    https://www.jegs.com/i/TCI/890/CMP3766B/10002/-1
    Perhaps with a vacuum delay valve? Seems simple and effective. 6” of vacuum seems okay to me for a cutout
    Also how will the other accessories be at the higher RPM? Probably ok since it’s only 5500rpm. It’s kind of funny, I started it up yesterday after installing the 3G to test it, and the original idler pulley started squeaking for the first time ever... good reminder I should replace it!
    -Phil
  9. #69
    40,020
    I used one of these in the Continental for that purpose
    https://www.ebay.com/itm/MINI-Vacuum...sAAOSwfkNfKuRi
    no manifold vac, the only thing it really does is keep the AC from being engaged before the engine is running and making the vacuum pump rotate. The original switch was bad and this got the job done. Probably about the same thing as the other switch, just half the price.
  10. #70
    Jan 2008
    New Jersey
    3,070
    That's even better, way more adjustability. I figure I'll see what vacuum i pull at 1/2-3/4 throttle and set it to disengage around then
    -Phil
