02 engine swap
    02 engine swap
    Engine started knocking. Found a 96 from an interceptor. What do I need to check to determine interchangeability. Low dollar as possible. Swapping parts from one to the other is fine, just not wanting to spend alot on mods or new parts.
    Well the 01+ are PI motors, and the 96 is a NPI motor, so it'll have less power.
    All the parts will swap over. You should just have to change the exhaust manifolds on it. And the TPS, and ...
    hmmmm
    As long as you have the old motor, this swap should just work.
    I'm used to doing this swap the other way, lol.
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
      Thank you Ryan. A little less power will be ok, 17 yo driver. It sounds like this will be easier than I thought. We will keep the original for a builder later if he decides to drive it for awhile.
