Results 1 to 12 of 12
Thread: Questions Reguarding Sway Bars
  1. #1
    I shall not pass this way again. Smokestacklightnin's Avatar
    Feb 2009
    Riverbottom, TX
    734
    Default Questions Reguarding Sway Bars
    Thinking about adding sway bars to my 2011 Merc. Not looking to auto cross or setup for race. Just want to reduce the amount of body roll for a more positive feel. So would I need front and rear sway bars, or just a rear? Should I stick to a stock size, or go to a larger aftermarket? Have never done mods to suspension other than replacing shocks, so any info would be appreciated. Car has 91K miles but the shocks and struts are still firm. I know I will need all the hardware since it does have any sway bars right now. How difficult of a DIY project would it be?
    NA-15.78@91.21, 80hp shot-14.48@96.21
  2. #2
    No mean-spiritedness here. IPreferDIY's Avatar
    Jul 2014
    Canada
    2,043
    If you're able to jack the car up and don't mind crawling under it, the sway bars are probably among the easiest things you can do. The most affordable approach would be to find bars and associated parts in a U-pull yard. IDK the technical details of matching what size with what, or year-to-year variations, or the benefits of paying extra for aftermarket stuff, but I don't see why most people wouldn't be happy with appropriately matched sizes from within the stock offerings. Do you not have any front bar at all? It seems that having a front bar with no rear bar has been fairly common, though I don't think I've ever heard of having no front bar.
    mods: air filter box "tuba" (in place of the "trumpet"), headlight relay harness, J-mod (around 186,350 km), 70mm throttle body, NKL4 PCM (from a 2000 CVPI, nothing great there apart from highway cruising), KYB Gas-A-Just shocks (after >202,000 km on originals)
  3. #3
    Nov 2014
    Evans, GA
    1,622
    On a 2011, you just need all the hardware from the donor car since everything already exists to mount the bar to. So essentially, sway bar links, bar to axle bushings, axle bushing brackets, bolts for the axle brackets, and the bar itself. It's a super simple job to add it. You can get the rear bar off any 1992-2011 equipped car.
    You can certainly upgrade your front bar with one from a 2003+ police car if you'd like if you want a slightly bigger one up there. For the rear, civilian/P71 bars are 17mm and HPP bars are 21mm.
  4. #4
    Feb 2009
    Riverbottom, TX
    734
    Yes it has the front bar. Just meaning if it is adequate or needs upgrading. So would I feel a noticeable difference with adding a stock rear bar?
  5. #5
    Feb 2009
    Riverbottom, TX
    734
    Leaning toward to buying all new components as opposed to salvage parts unless replacement bushings are readily available. Need to look into it further. Thanks for the replies.
  6. #6
    Jul 2014
    Canada
    2,043
    The wear stuff is links and bushings, and you would generally want new. The bushing brackets and fasteners for the rear bar are probably salvage items. I've seen front bushings sold with their own brackets, but not rear ones. One possible approach with salvage bars is getting them cheap enough that you can try different combinations as a learning experience. I'll leave the size-matching stuff for others.
  7. #7
    Apr 2015
    Southern Commiefornia
    2,345
    If you can find a late-model junkyard cop car it'll have bigger bars, that would be my go-to.
  8. #8
    GMN Regular EaOutlaw1969's Avatar
    Feb 2018
    775
    amazon has the rear OEM equivalent bar with hardware for like 122 bucks
  9. #9
    Feb 2009
    Riverbottom, TX
    734
    After considering the options and pros/cons, I ordered the rear sway bar and hardware kits from adtr.net.
  10. #10
    I post a lot...
    Dec 2011
    Yonkers NY
    4,161
    i find that great on the 08.
  11. #11
    Feb 2009
    Riverbottom, TX
    734
    Finally installed the new rear sway bar last week. Wow! What difference. Goes around corners like it's on rails. Install was fairly easy.
  12. #12
    I post a lot...
    Dec 2011
    Yonkers NY
    4,161
    Right!
