Results 1 to 12 of 12
Thread: where them number 19 orange clad juice boys?
  1. #1
    Ford Fullsize For Life! marquis_82_withneons's Avatar
    Mar 2013
    New Haven, Indiana
    1,225
    Default where them number 19 orange clad juice boys?
    anybody got a set of stock orange 19# injectors for a 4.6? i broke one working on the wifes p71... rather have a matching albeit used set.
    Charlette - Brown 1977 Ford LTD - 351 Windsor 155K Full Custom Pioneer system, green HID, interior & underbody
    Alesha - Black 1982 Mercury Marquis - 255ci 178K full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
    Daily Rice - Blue 1987 Plymouth Horizon - 2.2L 147K, Ghetto sound system, 5spd, BORLA #workbeater
  2. #2
    Jan 2008
    New Jersey
    2,843
    I have a set for a 96 351W...not sure if they are the same?
    -Phil
    +1982 Ford LTD-S Police Car. 351w, GT40 Heads, Edelbrock 1906 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. Baumann Shift kit.
    +1975 Maverick- Fuel injected 302, Trickflow 170 heads, XE270 cam, explorer intakes, 24# injectors, custom tune. T5 transmission, 3.55 Yukon Trac-Lok rear.
    +1989 Mercury Colony Park "Large Marge" Lopo 302. 3.55L K-Code Tow package, Baumann Shift Kit, Big brake swap, rear discs, HO intake/TB, custom exhaust.
  3. #3
    Mar 2013
    New Haven, Indiana
    1,225
    Quote Originally Posted by Brown_Muscle View Post
    To my knowledge, if they are the same color and # rating they should be same then right?
  4. #4
    Jan 2008
    New Jersey
    2,843
    Yes the connector should be the same too
  5. #5
    Mar 2013
    New Haven, Indiana
    1,225
    these are what im after, rock auto shows compatible with D6 part numbers? this is for a 03 p71.
  6. #6
    Apr 2015
    Southern Commiefornia
    2,261
    Are they EV1 or EV6 connectors? I have a set of 19s for a fox mustang.
  7. #7
    Jan 2008
    New Jersey
    2,843
    Ok mine are the old style..sorry
    -Phil
  8. #8
    Mar 2013
    New Haven, Indiana
    1,225
    Quote Originally Posted by knucklehead0202 View Post
    sorry, im not sure of the difference between the 2. what year of mustang is it?
  9. #9
    Member
    Apr 2011
    LI, NY
    72
    Quote Originally Posted by marquis_82_withneons View Post
    The electrical connector is a different size & shape. Ford racing makes an adapter that converts the newer style to plug into older style connectors part# M-14464-U2J. I have to check a may have a newer style injectors from a Marauder here.
  10. #10
    Mar 2013
    New Haven, Indiana
    1,225
    Quote Originally Posted by Mustang Eddie View Post
    newer style would be great. less to mess with. but i can always go to the yard and snip off 8 injector plugs. that is assuming the older style will actually fit my rails and intake
  11. #11
    Member
    Apr 2011
    LI, NY
    72
    The body of the older ones are probably too big to clear.Found the Marauder ones I have here but they are 24lb sorry.
  12. #12
    Mar 2013
    New Haven, Indiana
    1,225
    damn, yea i imagine the 24s would cause all sorts of issues. thanks alot though. appreciate the time... side note.. the little"hat" so to speak is the only broken part of the injector.
