Results 1 to 7 of 7
Thread: 1986 MGM radiator capacity (5.0)
    I post a lot... Toploader's Avatar
    May 2013
    1,744
    Default 1986 MGM radiator capacity (5.0)
    Gents,
    How many quarts of coolant does my radiator hold?
    Its five years since I changed the coolant and want to p/u the correct amount of gallons for the job.
    Should I go with 50-50 pre-mix?
    Thanks
    GMN Regular EaOutlaw1969's Avatar
    Feb 2018
    774
    Quote Originally Posted by Toploader View Post
    Gents,
    Thanks
    According to the site I provided a link below to it shows this for cooling system capacity
    12.6 liter / 13.3 U.S. qt / 11.1 imp. qt
    https://www.automobile-catalog.com/o...is_4-door.html
    I like to use distilled water with any cooling system ( what type of water are you paying for with the 50/50 Mix ? )
    May 2013
    1,744
    Forgot to mention that I use "No-Rosion" when I re fill. LOL.......the Prestone says water is RO.
    Quote Originally Posted by EaOutlaw1969 View Post
    Feb 2018
    774
    No-Rosin sounds like some good stuff.
    21,538
    If just refilling after replacing parts... typically 2 gallons of 50/50 is enough. If a complete engine replace and empty heater core... 3 gallons and you'll have some left over. My 93 with the F150 dual core radiator takes 3 full gallons on a radiator replacement (heater core not drained and some left in the block). So you shouldn't need any more than 3 gallons. I use 50/50 for convenience. If you have a spare container to mix in, distilled water and concentrate will save some cash unless you value your time.
    39,101
    About 2 gallons for a drain and refill is my experience. 50/50 or just buy one gallon of full strength and a gallon of distilled water. usually costs less, but Harbor Freight usually has premix for basically the same price I can make it myself. Go in with a 20% off and you're good. If not in a hurry and its not a waste of fuel, go twice and use the discount each time. Threre is always one on their webpage.
    May 2013
    1,744
    Thanks guys!!.............greatly appreciate the education. Just want to say that No-Rosion is a fabulous product, it should be on everyone's short list of must haves when dealing with automotive cooling systems.
