Results 1 to 7 of 7
Thread: 18x8 Wheels and Tires
    Jan 2008
    New Jersey
    2,927
    Default 18x8 Wheels and Tires
    I've looked through old posts-lots of stuff on 17" wheels.
    I was looking at 18X8 wheels with 4.5" of backspacing. I was looking at 245/50 wheels all around- not worried about the rear, but a bit worried about rubbing on the front. Going to be installing speedway springs, so it will be slightly lowered. Anyone have experience with these? They are slightly taller than 255/50R17's, however almost half an inch narrower.
    Thanks
    21,744
    That's only half an inch off center... so it may not have any issues since some folks run 9 inch wide up front and barely rub. If you do have issues... a half inch spacer would sort you out.
    Apr 2015
    Southern Commiefornia
    2,345
    With my 17x8's and 255/50's, 4.5" backspace, i rub fender turning into driveways near full lock, and rub the sway bar a bit at lock. Hope that helps. My car is stock-ish height, although my springs are totally hashed. Rolling the inner fender lip in front definitely helps.
    351W & F.A.S.T equipped
    Aug 2010
    Moore, SC
    470
    The big thing to understand is that not all tire sizes are created equal. I used to have 245/45/17s on my 01, I went to 235/55s, same tire manufacturer, same model of tire and ended up having to run my Eibach Pro wheel spacers to make them fit. And the 235 has 1/2 wider tread area than the 245s did. A size that may fit one car could be an entirely different story with another brand tire.
    EDIT: I may have installed 245/50s, I forget! Lol
    Nov 2006
    Dirty Jersey Yo!
    8,045
    Also depends on the wheels. My 245 45R17 tires on the American Racing slot wheels (4.5" backspacing) had no problems up front. The 17" x 7" P71 wheels with 235 50R17 (I think that was the OEM size) and 1.25" spacers rubbed the swaybar. Had I went with 1.5" spacers, I would not have had that problem. It seems to me it's all in the wheels.
    Told ya everything I know when I said hello P72Ford's Avatar
    Feb 2007
    In the 860
    7,177
    4.5" BS on an 8" wheel is 0 offset. 8" is the width between the beads, and does not include bead width. A tape measure across the outer edges of the wheel will show 9", for a wheel that is advertised as 8" wide.
    In the same way the diameter is not the gross diameter of the wheel, its the diameter at the beads.
    **2012 Ford Mustang Boss 302: 5.0, 6 spd, 3.73s; 17K miles Cruiser
    **2008 CVPI, Ex MSP Unit #420: 4.6, 3.55TL Flowmaster 10 knock offs, dark tint, JD Blitz Black, DD, CHALKBOARD
    **2012 Harley Davidson Wide Glide (FXDWG): 103, Cobra Speedsters, Cosmetics
    **2014 Ram 1500 QCSB Express 4WD Hemi/8spd TF/3L21 Truck Duties; Boesch Built, Cosmetics
    21,744
    Quote Originally Posted by P72Ford View Post
    Good to know. I wish all the sites I researched wheel sizes on would actually state that. Most of them give one thing or another (BS or offset) but not both and leave you guessing. I do know the offset of the stock wheels are centered and most panthers should be able to handle 9 inch wheels up front and 10 inch out back without issue (maybe a little lip rolling). Personally, I wouldn't run anything that fat unless I was autocrossing it. But that's just me.
