Factory location of ground strap. 1990 Colony Park
    Good day to all.
    Where is the location and how long is the ground strap in factory location of a 1990 Colony Park?
    My wipers totally quit working again after replacing the wiper motor and the wiper stalk/switch.. they worked for a week when they were not needed.
    I'm ready to try a new wiper control module. Where can I buy one and does anyone have a picture of the location?
    Thank you,
    Mike
    Which ground strap? There should be one at the tailshaft of the trans to body. Not sure on the length but its a braided thing. There is also a battery to engine connection and usually a battery to rad support connection.
      Thank you Gadget.
      The one I have not checked is the tailshaft.
      I thought there was one from back of the block to the chassis.
      Thank you.
        My 90 CP doesn't have a strap one the tail shaft. I do have one on the back of the trans bell housing bolt. WagonMan
        89 Colony Park
        90 Colony Park
        70 HEMI Daytona Convertible
          Thank you Pete
