1985 Grand Marquis 2-Door
    Some thoughts...
    First, it's really cool to see one of these keeping CFI and seeming to perform alright. I certainly wouldn't mind eventually making one of mine quicker, and I don't really believe in replacing an engine until it throws a rod or is otherwise not-live-with-able, so this is neat. Well done, and thank you.
    Unless I'm missing something, the mods in place are only ones that enable flow to occur better, but not "more". e.g. stock cam so the valves are still opening the stock amount, but heads/intake/exhaust that don't present restrictions. That's my guess as to why it's coping with it pretty well.
    In my early days with my Lincoln I had drivability issues that were very hard to chase down and I replaced pretty much the whole car chasing them. I did discover that there are multiple program revisions of the EEC-IV CFI ECMs, and multiple manufacturers of them, and some of them were better behaved than others in my car with all else being equal. e.g. so maybe there was a harness defect like an intermittent break that was a root cause to many issues (and I don't doubt there was), but one particular ECM ran the car properly despite that defect while the others did not. Perhaps your ECM swap accomplished the same.
    There is definitely importance in drawing a line between EEC-IV CFI (1984-1985 on the 5.0 in Panthers) and EEC-III CFI (prior to 1984 on the 5.0 in Panthers). Mechanically, they are the same system. Electronically, they are rather different. I have no experience with III but on paper, it is dramatically different, and way less capable of adjusting to its surroundings, as well as way less capable of working around faults.
    Current driver: Ranger
      Some thoughts...
      Kishy, thanks for your response. I learned from you that the CFI computer I have runs on the EEC-IV, and because of that, I was motivated to do these small enhancements. So I actually should be thanking you really for the motivation to even do all of this! And yes, we're still on the stock lopo cam right now but that might change soon, as I have everything necessary to do a hydraulic roller conversion.
      The camshaft I have ready to go in is a stock Cobra camshaft. My theory is that the CFI computer will accept the cam swap without a problem. The Cobra cam is on a 118LSA and it has real low lift numbers, something like .478 using 1.6 rockers. Also, it just recently occurred to me that the CFI system is basically like a speed density system right? Maybe that's also why the ECM is playing nicely.
      Either way, I do plan on making it a touch faster, and at some point it will be getting some type of power adder but for now I am enjoying this car every day as a daily.
      1985 2-Door: CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, ASP Underdrive Crank Pulley, Bilstein Rear Shocks, Rear Lowering Springs, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Ford Racing 4.10 Gear, Eaton LSD Differential - I own the fastest CFI powered box to the 1/8th mile: 9.658@70.74mph
      1991 4-Door (Dad's Car): Pro-M EFI, 306ci, Forged Pistons, Ford Racing Aluminum Heads, COMP XE264HR cam, Cobra 1.7 Rockers, Edelbrock Performer RPM 2 Intake, 30lb. Injectors, Custom 65mm TB/EGR Spacer, Pro-M 75mm MAF, BBK Ceramic Shorties, Custom Summit H-pipe, Walker Mufflers, Jegs Built AOD, Roadrunner 3000 Stall Converter, Ford Racing 4.10 Gear - Best 1/8th mile time: 9.76@72.03
        its speed-density yes. Manifold vacuum is key on these. Too low and it runs fat and stupid at low engine speeds.
        The big problem with S-D is that if you add more airflow, the ECM doesn't have much of a way to compensate. The O2 sensor has a limited trim range and it doesn't operate at full throttle anyway. Change things too much and the engine is just going to run lean because its moving more air than stock but it doesn't know to add more fuel. With tuning thats not a problem, but stock it only knows that with a given engine speed, throttle position, temperature, and vacuum level it gives an amount of fuel and ignition timing. You can cheat the fuel somewhat by bumping the pressure though. The injector is open for however long its open for, but with more pressure you get more fuel in that period of time. Too high and you run into the opposite problem though, it will run fat at low engine speeds because it can't control it down low. If you have stock heads though, I doubt the engine can move enough additional air to hit the limits. E5 heads and E7 heads are damn near identical so that shouldn't be a problem if they are just as-cast.
        The SEFI cars have the same limitation, its just a "feature" of speed-density EFI. mass air isn't inherently superior, its just more flexible because it directly measures airflow rather than having engine airflow data programmed into the ECM.
          I am certainly glad my experiences and explorations have been useful. I usually write my posts with an eye on what a future person who finds them might need or want to read. It leads to things being long and wordy, but my hope is it's usually clear and useful in the future.
          Very excited to see where you take this over time. My vote, for what it's worth, is to keep the CFI as long as is practical (e.g. when it starts costing you more to keep it than to get rid of it).
            Hello all. I was reading back through this thread just looking at all the progress I've made since 2019. I'm really glad I have kept my CFI unit on this build. It's almost become the highlight of the entire build. I am proud to show off my toilet bowl injection and happy that my 2 injectors are putting in work!
            Injector Ramblings:
            I pulled the part number on my injectors: EOSE-A1A . I have discovered that these are 46lb injectors.
            I have also discovered that the 1985 Automatic Mustang 5.0 also had a CFI unit bolted up to its 5.0L, and worked with 52lb injectors.
            I am inclined to purchase some TJ102 Injectors from Rock Auto that are a direct replacement for the 85 Mustang, and that will effectively deliver a greater dose of fuel through the CFI unit. I know it will probably be somewhat richer at idle, but I would rather do something like this than to get an adjustable fuel pressure regulator and bump fuel pressure on my 46lb injectors. I could see the 52's being well matched to the current heads/intake/exhaust. Can someone confirm or deny these interpretations?
            Cylinder Head Ramblings:
            Also just for demonstration purposes I have attached some pictures comparing the E5 exhaust ports and the E7 exhaust ports. The thermactor bump looks considerably larger on the E5 heads. It even casts a shadow on the valve. Both exhaust ports seem to have about the same surface area, but the valve on the E7 looks more streamline at the base of the valve head/stem. Just something cool to look at. Could this have added 1hp per cylinder? I could see it doing so.
            E5 exhaust port
            E7 exhaust port
            I Want To Go Faster:
            Some things I'd like to do before going back to the track to try and reach 70mph and a consistent 9 second 1/8th mile time:
            - tru-coil rear springs to replace the original springs. hoping this will help with the 60ft.
            - replace the 8.8 diff bushings. hoping this will help with the 60ft.
            - do the 52lb injector swap. hoping this will help trap a higher MPH
            - 155lph fuel pump. hoping this will help fuel delivery and help trap a higher MPH
            - remove the K&N air filter. This is my makeshift hat/K&N open element filter
            Feels faster without it so I know it will help if I remove it at the track. The times I ran were with this doohickey attached.
            I am still gathering the necessary parts/courage/motivation to do the hydraulic roller conversion. This will be done at some point but it is not on my top priority list.
            Anyways, I can't thank this community enough for all the knowledge y'all have shared and for all the kind words. It's really a blast driving this car around and I know it will get a bit faster from here on out.
            Thanks for looking and thanks for everyone's interest in this thread.
              Considering 52 vs 46 is less than 1lb/ cylinder I dont think it would make it that much richer, worth a try. Eventually if you really wanted to up the performance and keep the stock CFI unit, I wonder if you could adapt some aftermarket ECU to it and do custom tuning. I'm not sure whats out there that's compatible with a throttle body injection unit thats not mass produced like the Holley Sniper or FiTech
                Since the 85 ECM is EEC-IV I could potentially plug in a Moates Quarterhorse into the J3 port and have Decipha generate a tune for it. It's probably never been done though. Then again, nobody on here is trying what I'm trying (at least documenting it anyways). I could also possibly add a second rail to the CFI unit and another two injectors, and run it off of a batch fire PIMPXS. But that will definitely be way down the line if I do. I'm doing all this just for the sake of experimentation, and testing the limitations of the CFI unit. For me, it is fun to do as much as possible with the lowest tier fuel injection.
                  May as well skip straight to three CFI units, six-pack CFI for the win.
                    I'll do it gadget.
                    I'm out of my mind already.
                      Oh hell yes!
                      I found this a while back, someone has gone mad aswell. But in a similarly good way:
                      https://www.msextra.com/forums/viewt...?f=101&t=70311
                        Originally posted by Arquemann View Post
                        Oh hell yes!
                        I've seen this before! Yea this dude is a straight up madman. I totally understand why people hate on it and why no one would want to do it though. There are so many easier ways to achieve the desired results with less time, effort and money. Apparently that guy had it running on a 351 though. He was using four 52lb injectors. I might go ahead with the 52lb injector idea after all...
                          I don’t understand the hate and misinformation. Like one guy in that thread said something about inconsistent fueling across cylinders. Well a carb is setup the same way and are still being used. As long as you have good atomization I don’t think it should matter. As long as you have enough fuel to run stoich it’s a non issue.
                          Now if I still had my 85 ltd and unlimited money I’d probably go with a better cam, top end kit, bigger injectors and aftermarket ecu. I’d do it to prove a point. Look at gm, they used tbi for years and it worked. Cfi can work well too given enough time and energy is put into modifying it.
                            I find the experimentation interesting, but as is evident, a wasted effort in a sense. Everything can work, but is it worth it? No.
                            CFI/TBI is just the next step from electronically controlled carburetion towards EFI. I'd say CFI is as good as a-well tuned carb plus all the complexity and un-adjustability of a factory EFI system.
                            CFI/TBI is in no way better than the later MPFI, maybe excluding form factor. And the Ford sefi intakes are just dummy huge compared to chevys TPI.
                              I liked CFI in stock form, although GM's TBI is a superior system. So if I was worth a shit mechanically and electronically, I'd just figure a way to adapt mine over. The fact CFI doesn't compensate for cold enrichment or that it doesn't have an IAC is deplorable. Or maybe just adapt CFI from a 3.8 to a 5.0 as those did have an IAC. Why one but not the other?
                                For someone who already has a cfi car and put in a built motor, a modified cfi unit would be worth it. It’s far more effort to convert over to mpfi. Yes it is superior but, for the most part, it’s plug and play. Now adapting an iac and removing the high idle cam like the guy in that thread was excessive. I’m strictly talking about a slightly modified cfi unit to allow more flow for a higher hp motor.
