AC Evaporator Drain Hose Location
    Can anyone please tell me where the AC drain hose/tube is on a 1989 MGM? For some reason I just cannot find it and it's driving me insane. Thanks a lot.
    I am not sure why they would change the location but I found a clear picture online for a newer model
    this is where I would look first.Click image for larger version
      Not quite what that is. Thats the drain for the fresh air intake. The evaporator is to the left of that, in the engine bay, not inside the dashboard.
      The evap drain does not have a hose. Its just a small gap in the bottom of the evaporator case up near the firewall. Best way to find it is to lay under the car on the passenger side and shine a light straight up along the firewall. Where you see the evap box sticking out, you'll find the hole where the evaporator drains right against the firewall. If your car is like most, you'll find its directly above the rusted spot on your frame. If you're unlucky, like many, it will be above the badly rotted part of your frame.
        your right gadget I was still asleep when I tried to help, now that I look at the picture better the drain pointed out in the picture would be too high to be a evaporator drain.
          Thanks a lot guys
