Box master cylinder: super stupid question
    I am POSITIVE that this is a dumb question and I apologize, but I am vexed.
    A fitting on the Squire's MC is leaking. Of course, I didn't take a picture of it before wrapping it up for its winter slumber. So I'll just have to describe it as best as possible.
    It's the fitting that goes into the port in the middle of the passenger side of the unit, shown here.
    The leaky fitting LOOKS like what is in the Allstar box, shown here.
    My buddy thinks there is some sort of check valve or prop valve in there. I don't know that I believe it.
    Someone able to point me toward what I'm looking for at the parts store, or provide any additional wisdom?
    '91 LTD Country Squire LX | '82 Cougar GS wagon |'03 Marauder | ' 18 Flex Limited EB
    formerly: '02 MGM, '04 MGM, '04 MGM v2.0, '04 MM, '07 P71 w/5-speed, '03 SAP P71, '04 CVLX (now in pantera77's stable), '10 P7B
    likely it is the combination valve for the rear drum brakes. It is a proportioning valve to balance front disks to whatever size drums were on the car. It is also a residual pressure valve which keeps a few lbs. of pressure on the rear system so the drums apply in synch with the front disks.
    Is the rear converted to disk? If you don't have drums any more you don't need/want the pressure component at all. As far as proportioning I added an adjustable proportioning valve. Also gutted the component you mentioned and drilled out a slightly larger hole in it.
    This pertains to an 89. A 91 may be different but still had drums so basic functions should be the same.
      You are correct, that is a proportioning valve. If you can't find a new one, I have some used ones. WagonMan
      89 Colony Park
      90 Colony Park
      70 HEMI Daytona Convertible
        I still have drums out back.
        Appreciate the info and offer.
        This seems like something that should be available on the aftermarket and a parts store should be able to source. If not, I will be in touch to buy one off of you.
          So far, all I'm seeing online is valves for the E/F series vans and trucks.
            I unscrewed the one I took the picture of, It has an O-ring where it meets the master. Check that first. WagonMan
            89 Colony Park
            90 Colony Park
              Really appreciate the information.
              The car is wrapped up for the time being, but I will open it up come springtime and check it.
              Thanks.
                Hi, I just saw this post. I would like to have one of those valves also, just in case (as a spare). How much for it? Would you ship to 33126 (Miami, FL). PM if you are interested in sell one. Thanks!
                  sometimes new master cylinders come with them.
                    May be. But I have installed 2 MC (the first one was a Wagner, back in 2005 or 2006) and some months ago I replaced that one with a Bendix unit. None of them came with that valve. That's why I would like to have a spare.
                      I have not seen any in the parts stores nor online that came with them. Not saying they don't exist, just that they're rare.
                        Exactly.
                          1990CROWNVIC, I sent you a PM, WagonMan
                          89 Colony Park
                          90 Colony Park
