Ford can’t reprogram my Speedometer. Need solid advice.
    Good to know. And yeah, tune would solve all the issues in one go. Ask them if they can delete the stuff you don't have connected before you hand over any $$$ though. Some places can't/won't mess with emissions stuff.
      That’s good info right there. Thanks. I’ll see what they say, but before Intake it to them I need to fix the trans cooler, because it’s thermostat bypass thing in the cooler is broke and not letting it actually go into the cooler. Any ideas If there’s a “delete” kit for the thermostat on that so it always goes to the cooler?
        Drill the thermostat out. It's basically just a thermostat past the first or second plate. Or replace it with one that doesn't have a thermostat.
          On this one it’s in the bottom of the A/C condenser. There’s a spring loaded thing in the side where the hoses the
          Hook up.
            oh... that one. The worst one. You can still remove the spring, drill holes in the plug, or just don't use it and get an aftermarket cooler to mount up front.
              I'd go that route. Screw that integrated cooler thing. I get the idea of the thermostat, and I don't even mind it, but they don't seem to be all that reliable and not being serviceable is a "screw that" from me.
                Ya, I have a cooler here I’ll prob install and don’t worry about the stock one at all.
