Idle drop in park when hot
    When I put my car in park after driving it the idle drops to the point of almost stalling then shoots back up repeatedly. It idles fine in all gears while hot, and in park when the engine is cold. I've tested and cleaned the egr valve and iac valve. The only code it's throwing is 18, sprout circuit open. Could it be related to that? What else should I be looking at?
    You mean 218 spout circuit? Wouldn’t that have to do with the TFI module? So that would have to do with timing, so I’d say that would be part of your problem. Could be a bad plug, unplugged wire, or broken wire.
      2 digit code system, its 18.
      are you running a grey TFI module? Apparently switching the grey for a black will do stupid things like this.
      I have a 1989 Mustang GT 5.0 5 speed the month I have a 80 millimeter mass air meter calibrated for 24 injectors 65 throttle body Holley intake manifold upper and lower ported stock heads 1.7 rocker arms 24 injectors BBK shorty headers Dynomax super turbo mufflers with pipes stock H pipe with...
      has some troubleshooting for that problem. Apparently when you get that it loses timing control, which is a big part of idle speed control.
        It's the grey one. Noticed two other things, unsure if they're related. 1. When it's idling in park, if i quickly push the gas and let off the rpms stay up for a couple of seconds after i take my foot off the gas. 2. When i start and turn off the car I can hear the metal vacuum canister on the driver side pop. I've read that my issue could vacuum related.
          that won't have anything to do with the error code. The hanging idle could be vac leak. The pop in the can sounds more like a bad check valve though. It shouldn't bleed vacuum off that quickly.
          never actually had anything with an 18, so I don't honestly know what the symptoms are.
            I had a code 18 once. Forgot to put the SPOUT jumper back in after setting the idle after adjusting the timing.
              Thought I'd update in case anyone with a similar issue comes across this thread. I put in a new TPS and that helped the idle significantly. Then I put in new ECT and ACT sensors which helped even more. It doesn't have an issue with the idle dropping now but it still doesn't feel right sometimes so I'm going to put in a new TFI module this weekend and reset the timing.
