Results 1 to 19 of 19
Thread: EGR plate and TB for explorer intake onto LoPo
  1. #1
    Member clutch47's Avatar
    Apr 2019
    near Knoebels Grove amusement park
    441
    Default EGR plate and TB for explorer intake onto LoPo
    Picking up an explorer intake upper and lower from a friend over the weekend.
    Looking for proper parts to adapt it to Sherrie. EGR plate and larger flipped TB would make it right I think..(?)
    My original lower is leaking oil in the back like many do.. so while it's off, I'm going to put on the ported lower and upper from this explorer.
    WTH right..? I have some parts to trade too..
    All FORD All The Time
  2. #2
    Nov 2014
    Evans, GA
    1,515
    Need a F-150 Lightning EGR spacer to use an Explorer intake if you’re retaining EGR. It also keeps the bracket mounting points right for the TV cable and throttle cable. The LoPo spacer can’t be bored out large enough, IIRC.
  3. #3
    38,361
    I've halfass wondered if the lopo spacer could be cleaned enough so that the entire EGR area and the water passage on the other side could be filled with JB Weld or something of that nature. Once both sides of the thing are packed full, maybe it could be machined flat and bored out. At that point your spacer would be a chunk of bullshit and hope that only serves to mount the throttle cable. And it might not work.
    but the Lightning part is the preferred way. The not so preferred way is to use a Mustang thing and make up a new bracket to mount the throttle cable bracket to.
  4. #4
    Apr 2015
    Southern Commiefornia
    2,311
    ^^^I've thought about this same thing but it does seem a lot of work to make a chunk of bullshit, which is the exact term i'd use for it. Even the lightning spacer doesn't give you much wiggle room if you want to go bigger than a 65mm TB. I intend to use a 70 or 75 on my 347 but not sure i can hog that spacer out and still have enough surface to seal. Don't intend to use the coolant circulation part but do have to keep EGR for gay california.
    Anyhow KW, let me dig in the garage, I know i have the modded lightning TB and egr spacer still laying around from the other car and i'll set you up. Not sure what is even a reasonable price these days but we'll figure something out.
  5. #5
    38,361
    A Fox part could be adapted if you make up a bracket to mount the throttle cable bracket to. Honestly thats probably the more sensible use of time vs the JB Weld method. Some angle iron with careful trimming so it bolts under 2 of the throttle body bolts and extends down to the correct location for the cable mount would get it done. Maybe weld in a spacer to duplicate the stock bosses so the pedal travel is where it belongs.
  6. #6
    Apr 2019
    441
    So...this explorer intake upper has a BBK 70mm EGR adapter on it..
    Can't the studs be flipped and the whole Johnson be reversed to make it where it needs to be.? I don't have Sherrie here now to look. She's off for a winters nap..
  7. #7
    38,361
    This is the Lightning part
    The two ears on the left are what most things use to mount the throttle cable bracket
    The two bosses on the right are what Panther throttle cable brackets bolt to. If you don't have those bosses, there isn't any flipping to be done. The only practical solution is either this magic part that happens to bridge the gap, or making a bracket to do it. Piece of angle iron with some creative grinding and two short spacers welded onto the angle iron to duplicate the spacing would serve. I'd mock the thing up, drill the holes, and tack weld the spacers in place. Prob insert and tack the bolts from the adapter bracket side so all you have to do is thread nuts on the throttle cable bracket rather than having to try and assemble the whole thing half blind with one hand.
  8. #8
    Domestic Tourist Lincolnmania's Avatar
    Sep 2004
    Birdsboro PA.
    17,379
    you could use the fox part and fox cables.
  9. #9
    Apr 2019
    441
    Thanks for the Picture.
    So I'm just going to need the correct throttle cable mounting bracket then. I'll use some aluminum nuts,and spacers... mount the bracket up in a jig, and weld it all to the EGR plate with the bracket located correctly..so it'll be a bolt-on affair when she comes home from storage.
    So...anybody got a throttle cable bracket they'll sell me that is proper for my '86.??
    WTF was FoMoCo thinking making all the parts for this model different from EVERYTHING else.? It's kinda funny..
  10. #10
    Just don't break the AOD TV cable when you move everything around. I cracked the plastic part of mine where it mounts in the bracket, it's held together on JB Weld and a prayer. If it breaks, I have no idea where I'll get another, so I'll have to start searching out 87+ TV cable parts...
  11. #11
    Sep 2008
    Whitestone, NY
    18,815
    Quote Originally Posted by bgreywolf View Post
    This.
    I obliterated one in the yards. First time touching the 86 style...I grabbed the throttle linkage so I have an 86 one to offer when I sell some 65mm throttle bodies I have on hand after powdercoating them. For the curious...I removed the two throttle shaft bearings and will be installing new ones in these powdercoated units.
  12. #12
    Apr 2019
    441
    This.
    I'm kinda running blind here. As I said I don't have my car here right now, as she's in winter rest mode under my friends business, and I haven't ever worked on one of these exact models...so I really have no idea how it goes together.
    Would you part with the linkage/bracket you have.? When this all gets installed I'll likely be putting on a new TV cable if I can source one.
  13. #13
    Sep 2008
    Whitestone, NY
    18,815
    Quote Originally Posted by clutch47 View Post
    I dont want to part with mine. I want it available with the throttle bodies I have for sale so I can cater to the 86 crowd as well...open my market.
    You can simply grind off the metal on yours and press it off and install it to your new throttle body so you can retain the same TV cable setup. I used to resort to the weld on method but have taken a liking to the drill and tap method in retaining the throttle linkage to the throttle shaft.
  14. #14
    38,361
    I also drill and tap them, but I do it on the lathe since its a hell of a lot easier. Also I own a lathe but I don't own a welder so there is something about using the tools you own.
  15. #15
    Apr 2019
    441
    Understood. Thanks.
    Mind educating me on throttle bodies.? This car is my first EFI that I'm modifying in any way.
    I made up my mind and started this project on my stock bottom end.
    I have:
    AFR 165s.. #1472
    I swapped a 650 spread bore for an Early Explorer upper and lower. 70mm BBK EGR plate. All are in the mail to be ported.
    BBK unequal shorties.
    depending on what the clay says when the heads go on...I might bite the bullet and get my local cam grinder to make me a LoPo style on steroids that will keep the vacuum up to appease the computer.
    I also scored a brand new in the box Edel/BBK 75mm throttle body for bartering if it's too big. I'm not quite convinced it is, but I'm willing to learn.
    This is why I'm trying to source the throttle hardware. Less car downtime..
  16. #16
    Sep 2008
    Whitestone, NY
    18,815
    I really only know the stock type stuff. If the butterfly does not get obstructed by the egr spacer than it may work. Also have to take into account sealing surfaces, then check if you can swap on the proper linkage to adapt to your TV set up.
    I dont see any of what you are doing working with stock speed density though.
  17. #17
    Apr 2015
    2,311
    I can say that a 75mm throttle body will fit and seal on a lightning spacer, and the step is minimal. I may have a buddy clean it up with a die grinder. The sealing surface at that point with be narrow but should be ok.
    Also, on a stock lopo, a top-end swap with heads and intake drastically changes the power curve. Low-end grunt goes away and it behaves more like a mod motor. My other car had Edelbrock performer 170 heads, typhoon intake, 1.7 rockers, lightning tb and spacer, and 24# injectors. It was a turd off the line but pulled like a train mid-high. Having no tach i couldn't say exactly where but i basically would shift out of fear. Damn thing kept pulling though. My heads had 62cc chambers and it notably increased compression. What is chamber cc on stock lopo garbage?
  18. #18
    Mar 2006
    Bedford, VA
    5,346
    IIRC the E6SE heads have 69cc chambers for 8.9:1 on a stock piston.
    1988 Crown Vic Wagon - daily
  19. #19
    Apr 2019
    441
    My fall back is the Megasquirt.. if it won't. Fingers crossed.
    Quote Originally Posted by knucklehead0202 View Post
    This.. is what I'm trying to avoid. I really like the LoPo Go... That's why I'm thinking the custom cam might help.
