I have owned and driven this car from 2003 to 2014. It had always ran great with no problems whatsoever. In the fall of 2014, just before I put the car up for winter storage, I noticed it was loosing power and I had a couple times where it took a long time to get it started. In the spring of 2015, I started it up(same issue) then it was switching back and forth between running really rough with the loss of power and then smooth. Then it stalled on me and I have not been able to start it since. Here is a list things I have done, replaced and checked.
- It did have spark.
- Fuel pump comes on, I also checked at the throttle body for fuel pressure and it had fuel pressure. I even used some starter fluid just to be sure and that didn't help.
- I replaced the ignition module on the distributor.
- I put in a new oxygen sensor.
- New ignition switch.
- New spark plugs and wires
Any suggestions on what route to next are appreciated.
