Results 1 to 17 of 17
Thread: Replace TFI
    Member Rock_Hound's Avatar
    Dec 2019
    Somersworth, NH
    29
    Default Replace TFI
    Hi all,
    The TFI in my CP is original from the factory and I have been looking to replace it as part of an ignition overhaul. Unfortunately, I have been having a difficult time sourcing a Motorcraft part. Is there any preferred aftermarket brand that you have been having good luck using? Part numbers that I should be looking out for? I do have some Amazon gift cards and, while they are not my normal parts source, it would be great if I could use them to pick up this part. Accel 35369 keeps popping up in my searches, but I know nothing about them.
    Thanks!
    Nov 2014
    Evans, GA
    1,562
    Haven’t had any experience with the Accel TFI.
    The Motorcraft P/N is DY-1284. I currently am using that on my car.
    I’ve also used Standard Ignition LX218. BWD is under the the Standard Motor Products umbrella, just if you happen to find them instead for that application. Both of those are decent as well.
    Just avoid el-cheapo no name units.
    21,412
    Most of the store brands are also Standard or Airtex/Wells and are decent as well.
    38,732
    the only one I've ever had barf on me was an Accel part. Engine shut off at an intersection and that was it. Luckily a police officer happened by and helped me push it out of the road. I've had the same "cheapest listed" one from Napa on the car ever since. That was more than 10 years ago. The Accel part was less than 6 months old. The "emergency spare" that got me home was an unknown mileage old Motorcraft on an extra distributor I had.
    Dec 2019
    Somersworth, NH
    29
    Thanks guys. I ordered a Standard Ignition LX218, which is readily available from RockAuto.
    Gonna buy me a Mercury BoulevardRide's Avatar
    Jan 2018
    ne
    158
    Would you mind posting an update if you get installed how it works for you? thanks
    96 MGM
    cruise it up and down the road
    Sep 2014
    Warren, MI
    5,799
    If the original Motorcraft unit is still working, keep running it and source a spare from a wrecked car from a yard. That's how I roll.
    Dec 2019
    Somersworth, NH
    29
    The original is not functioning well. It caused the motor to die a few times inducing this morning. Thankfully it died on me this morning after I made it into the parking lot.
    38,732
    could also be the pickup coil in the distributor. Similar fail modes. If the TFI doesn't sort it, the pickup is the next likely item.
    Dec 2019
    Somersworth, NH
    29
    Thanks for the tip. The wagon sat for several years before I picket it up, I am slowly refurbishing it while still daily driving it. The TPS was also faulty and swapping that out fixed many of the issues.
    38,732
    Things get crusty. Worth a look at the fuel pump and ECM relay sockets while you're poking at stuff. They live near the washer bottle under the covers. Brown is ECM, green is fuel pump I think. Mine had mostly bare wiring in that area and the sockets were crusty. If the relays are sketchy, shaking them around will probably make the engine stumble.
    Dec 2019
    Somersworth, NH
    29
    Thank you! I will check on those as well. I plan to make this machine my daily driver. Currently I drive it, but I wouldn't want the wife to until I get it running a little better.
    Sep 2014
    Warren, MI
    5,799
    Exactly this.
    Mar 2007
    North Las Vegas Nevada
    2,328
    In my case I had a crap Distributor from Advance Auto so after suffering aggravation I went and bought an MSD Distributor and so far no problems in starting and running of my CV.
    Apr 2015
    Southern Commiefornia
    2,345
    I have 3 spare motorcraft distributors i've collected so if something goes bad, zerp, and flerp. Done.
    Dec 2019
    Somersworth, NH
    29
    Just a quick update. Everything is running smooth as of right now. Between replacing the TFI and the TPS there is no longer any stalling at idle or while in motion. All stumbling is gone and the wife even feels comfortable driving it.
    GMN Regular slack's Avatar
    Mar 2013
    Long Island, NY
    1,254
    Glad to hear everything is working out.
    If only I could get my wife to be comfortable with my '78 even though it's so far our most reliable car.
