Results 1 to 20 of 20
Thread: Cheap reman p/s pumps
  1. #1
    all the CFI are belong to me
    Feb 2014
    Windsor, ON
    1,651
    Default Cheap reman p/s pumps
    I was looking for certain cheap things and stumbled upon what looks to be a U-Haul clearance warehouse - selling U-Haul brand products that are discontinued or "scratch and dent", and also what look like surplus items from their truck maintenance network. I found this while looking for another trailer hitch, and stumbled upon a new one for 49 USD shipped. Obviously, yes, I now own that hitch.
    Among the items are these power steering pumps.
    https://www.ebay.com/itm/201786666676
    The given part numbers are
    F0TZ3A674AX (90-96 Ford Trucks if you take the X off)
    E8TZ3A674BX
    E8TZ3A674B (many things, but interestingly does list the Mark VI, but not other Panthers)
    If I am thinking correctly here, these might fit our cars but just have a different pressure regulator doo-hickey in them, so the steering weight might be a bit off but otherwise a functional replacement.
    I'd appreciate any feedback supporting or contradicting that line of thinking.
    83 GM 2dr POTM 10/2019 | 84 TC POTM 1/2017 & 4/2019 | 85 CS | 85 Ranger | 91 GM POTM 12/2017 | Junkyards
  2. #2
    38,376
    just swap your original regulator, problem solved. The only real difference in Ford PS pumps are the regulator and sometimes the reservoir. Hydroboost things had an extra return nipple. Might be worth buying one of these. I've got a leaker on the Continental that I've been meaning to pull and re-seal but 40 bucks is hard to beat.
    I bought a 100a 1g from these guys a while ago as a spare. Has some useless (to me) pulley on it but its a brand new alternator of the same type 2 of my cars use. Each uses a different pulley anyway so I'd still have to swap. I think it was 30 bucks? Way cheaper than the usual sources.
    prob not so much scratch and dent as just obsolete. These things don't fit anything made in the last 20+ years. Prob just reclaiming warehouse space at this point.
    **edit**
    looks like they aren't out of alternators
    https://www.ebay.com/itm/FOPZ10346C-...YAAOSwyQtVhGt~
    useful for you guys with 100a stock alts still.
    or if you want to convert it to a 3g without buying small case brackets, pretty sure this is the animal
    https://www.ebay.com/itm/UHR307-New-...8AAOSwH41dwKTW
  3. #3
    Feb 2014
    Windsor, ON
    1,651
    The 3G you linked is an interesting one. I think the photo is the small case. Complete backwards clocking for use with our stock accessory layout...but that's fixable.
    However, one of the the given part numbers comes back to a 95A which appears to be large case (per RockAuto, per Power Select). Applications are wonky on that one. '90 Town Car and some of the 92-98 medium duty trucks, nothing else.
    The other given part number comes back to a side-mounted 95A like my Ranger 2.3 takes.
    It's a solid deal, whatever it is, but accurately figuring out what it is will probably involve just buying it and finding out.
  4. #4
    38,376
    even if it is the 95a version, its still an upgrade from a melted 65a 2g. Most of us would never really get anything out of that extra 35 amps of capacity.
  5. #5
    fomoco panthers !
    May 2011
    Bangor,Maine
    2,951
    I am considering the F0PZ, 100 amp as a spare for the 90 CV police car. Should be a direct fit.
    The second one IF it would be a fit without re clocking, I would get 3 of those to do the 3g retrofit on 2, 89 TCs and the 83 Merc.
    Any advise ?
  6. #6
    Feb 2014
    Windsor, ON
    1,651
    Quote Originally Posted by Mainemantom View Post
    Any advise ?
    The issue with the 3G is that the part numbers given come back to two completely not-interchangeable examples. If it is the side-bolt version, it can only be used on things that are not Box Panthers, basically.
    I'd suggest contacting the seller and verifying which part it actually is.
  7. #7
    38,376
    so I bought one of the PS pumps. I'll let you know what shows up.
    Tom, if you want to use the 100a on the Vic you'll have to change the pulley. NBD. I can pull mine off the shelf for some pics and measurements if you want to confirm tho.
  8. #8
    fomoco panthers !
    May 2011
    Bangor,Maine
    2,951
    I just ordered the 100 amp for the 90CV. Checked with R.A. It is a match. Great deal ! EB seller has plenty too. Got to do the pulley change over which is easy.
    I think I had better pass on the other. Cross referenced and it did not match exactly. I will be doing the 3G upgrade on the other cars soon. Just need to get good deals on all the required parts.
    Thanks for the input.
  9. #9
    Member Arquemann's Avatar
    Jul 2019
    Finland
    203
    Does a 60A stock interchange with a 100A one? ('85 MGM)
    $30 for a reman unit... Here I paid 190€ for a new stock 60A unit, even had to swap the pulley from the old one.
    1985 Mercury Grand Marquis LS
    1997 Volvo 850 GLE Estate
  10. #10
    Mar 2010
    Lewisville, TX
    21,332
    maybe... maybe not. The 100A is a 1G and uses an external regulator for use on the carbureted models and models with the heated windshield. The 60A could be a 1G low output for base models and carbureted models while the 2G with an internal regulator was used 86+ on EFI cars if I remember correctly. If your alternator has the internal regulator, you'll probably want to do the 3G swap to eliminate the quick connect charge wire fire hazard. If you have the 1G, you only need the 3G swap if you really need more power. The 1G alts have complete bolt on connections and are not a fire hazard.
  11. #11
    Jul 2019
    Finland
    203
    This is what I had before, and a similar (but shiny) chunk I replaced it with. From my understanding (and the case says 60A) it is a 1G, it has an external regulator (which was actually the culprit when the charging system stopped working last year.
    My MGM is an LS and has CFI though...
    And the 3G swap would be the smart choice were I to upgrade?
    I'm reading through a lot of stuff as I'm contemplating / planning on a carb swap since my CFI has been a piece of ass so far.
    I should do a Reader's Rides thread on my car to consolidate all my ramblings to one place.
  12. #12
    38,376
    The 100 amp is bigger. The upper bracket needs to be changed in order to go from the 60 to the 100. If I were looking to upgrade the alternator, I'd go 3g 130 amp in the small case. It fits your stock brackets. Needs a little more wiring mods, but wire tends to be more available than limited production brackets that have not been made in almost 30 years.
    electrically speaking, the 1g 60a and 1g 100a interchange, though the charge cable and fuse link probably ought to be a wee bit heavier for the 100 amp.
    honestly those old alternators are really easy to rebuild. Most of the time its just worn out brushes, or bearings if its noisy. Both are cheap, and if you're doing brushes I would definitely change the bearings. The slip ring can also be had for not stupid money. The only part that is at all difficult is the rectifiers, and thats mostly because you need a big-ass soldering iron to connect them.
    The 1g doesn't have amazing idle speed output but its fairly reliable. The 2g has slightly better idle output, but its got a crappy connector that melts and catches fire. The 3g has neither problem. 4g and up are apparently better yet but they don't exist in a package that fits our cars.
    the only reason I bother with the 100 amp is I own 2 cars that use it. The large case 3g can be made to work, but the upper ear is fatter so it needs some modification. The Mark VII I can change the brackets to Mustang parts and use a small case stock 3g. The diesel Continental, no such luck. It was just easier and probably cheaper to stock a $30 new one than it would be to get a used one and rebuild it as a shelf spare.
  13. #13
    38,376
    so the PS pump got here. Looks fine. D8 part number on the pump body, E8 on the reservoir. Looks exactly like a Panther pump. Its not painted, but that can be fixed or ignored as you see fit. Packed nice, bagged and tagged. I put the whole box on the shelf.
  14. #14
    fomoco panthers !
    May 2011
    Bangor,Maine
    2,951
    That U haul seller has three types of transmission coolers available. Light, medium and h.d . decent prices. Also surprised to see new factory seat cushions and covers for trucks. I guess a part distribution center is clearing out inventory.
    The local Uhaul place has a really nice new F150 that I would love to have. Standard cab, chrome wheels, chrome bumpers and grille. long bed. Uhaul must have got a great deal on it.
  15. #15
    38,376
    I'd like to find a standard cab short bed but I don't think anyone makes one now.
  16. #16
    fomoco panthers !
    May 2011
    Bangor,Maine
    2,951
    I have seen two new GMC standard short beds on the dealer lot. The red one looked really sharp with the chrome package, and I don't like GM. I have seen one Dodge which was plain ugly. Ford has the long bed and one that is shorter. Don't know if it the real "short" bed. They are getting hard to find. Must have to special order. From what I understand, resale value on those are in the toilet. That is exactly how I want to buy one. When the market says no one wants them.
  17. #17
    Mar 2010
    Lewisville, TX
    21,332
    I've seen fleet models in standard cab short bed. Not sure if you can get that on the consumer side though.
  18. #18
    fomoco panthers !
    May 2011
    Bangor,Maine
    2,951
    Just today I saw a new Chevy 1500 standard cab short bed 4wd, v-8. on sale from $35,000 to $31,000 . Next to it was a 2019 Chevy 2500 Crew cab 4wd. on sale for $36,000. Value for the money, no wonder no one wants the standard cabs . I still like the standard cab. I would like to buy one at auction as a lease return or a repo cheap.
  19. #19
    38,376
    all the dealers around here have them in long bed only. Even GM's website only offers an 8' bed if you want the reg cab. not sure if fleets can get a short bed, or if thats just completely a thing of the past. Mostly I just don't want the wheelbase. It makes them impossible to park.
  20. #20
    Mar 2010
    Lewisville, TX
    21,332
    I think I've only seen them in Fords. And maybe only F250. But I know it was fleet only. And probably special order only.
