Results 1 to 2 of 2
Thread: LMC Truck relay harness
    Member Rock_Hound's Avatar
    Dec 2019
    Somersworth, NH
    29
    Default LMC Truck relay harness
    I want to put in a headlight relay in my 88 wagon. I would prefer to have something that I can easily switch back to factory. Searching on this forum, I found several people mention the LMC harnesses as a good option.
    Just wanted to check to see if I was finding the correct part. I saw only one part number mentioned in any of the threads; 36-3581, for an 81-88 Chevy. I just wanted to check if anyone can confirm before I pick one up.
    https://www.lmctruck.com/1973-87-chevy-gmc/gm-heavy-duty-headlight-harness
    39,117
    I have a similar one on my Continental, but it was a cheapo Chinese thing from Ebay for about 20 bucks. It was sold for H4 lamps, which needs 2 wires switched. Not a big deal, but if you can get one for 30 that doesn't require moving wires, not a bad deal. I also wanted a plug and pray one that involves zero wiring harness mods. I could plug the stock wiring back in if I had to. The one on the Towncar I made myself, but its of a similar design that doesn't modify the wiring at all.
