Page 3 of 8 FirstFirst 12345 ... LastLast
Results 41 to 60 of 151
Thread: VicCrownVic's 1998 Mercury Grand Marquis LS
  1. #41
    39,650
    the wiper parking thing I believe is a cam inside the motor gear assembly. Might be able to swap the one out of the 95 motor into the original and make the wipers behave as they should.
  2. #42
    Nov 2012
    Shelby Township, MI
    3,238
    I've got an original '91 motor I can rip into. Perhaps I'll take a look at that today to get a better idea of the inner workings.
    Gone but not forgotten:
  3. #43
    21,797
    The timing set on my 93's original engine was still in okay shape when the engine ate a valve at 200K. You could however SHAVE with the ends of the cam gear teeth. Those things were sharp. It definitely was showing signs of wear, but it still ran fine until it bent that valve. The general theory is that the unremoved casting flash on the head caught the intake valve and held it just long enough for the piston to slap it. We had just replaced the valve stem seals too. There's additional theory that the valve spring was too soft, but we never measured that.
  4. #44
    Jul 2014
    Canada
    2,043
    ... Both Dorman parts but I assume, unlike the intake manifold itself, that these parts are ok?
    I was a bit hesitant at the idea of removing the water pump to replace the nipple, but I'm used to the 5.0 where every accessory attaches to at least one point on the water pump. The 4.6 water pump is just a few bolts and that's it?
    I'm sure I'll have plenty more dumb questions since I know absolutely nothing about anything 4.6 specific.
    The 4.6 is reasonably straightforward. For me, it's always a matter of the engineers seeming to make things without much regard for repairs, and that's probably the biggest issue rather than any kind of intrinsic complexity. Dunno about the Dorman pipe and nipple, but it's hard to imagine they could mess up something so simple. I'm not sure if replacing the nipple is actually necessary if your pipe does not have the little piece of hose where it sits on the nipple, but I'll leave that for someone else. The water pump is indeed that simple.
    Something quick that you could do without spending any money is removing the restrictive trumpet from the air filter box if you haven't already done so. That in itself should give you some sense of whether you want to bother with the other stuff.
    Also, I forgot to note that the 70mm TB might result in the gas pedal being a bit higher, and you would most likely have to readjust the cruise control cable in any event (remove clip, let cable extend, reinsert clip). If you want to guarantee that the pedal will come up, you can use one of the plastic TB comb gaskets after removing the combs. My gas pedal is almost level with the brake pedal, which works for me.
  5. #45
    Southern
    Apr 2013
    Columbia, SC
    922
    You do not need to worry about timing chain guides or tensioners since you have the much better design. You already have metal tensioners. (which is what ford used to replace the 2001-3s during the recall).
    2004-2011 4.6s use a stupid plastic tensioner garbage setup. It causes the engine to knock at start up while they pump up. If ford had stuck to the metal design that they used for nearly two decades, things would have been fine. But to save a few bucks...
    I would not wait on the intake. Ill show you a picture later of the failure the 96-01s. Believe you can use/modify a ford motorsports intake instead of a Dorkman intake.
    -Nick M.
    Columbia, SC
    66 Squire, 89 Colony Park, 90 TC, 03 (2x) TC, 06 TC, 07 TC
    03 BMW 540iT, 04 Ford F150 4.6 XLT Reg cab, 8ft bed
  6. #46
    Nov 2012
    Shelby Township, MI
    3,238
    I think I was wrong about the '95 (single connector replacement for '91) wiper motor. Now that I have a service manual I looked the wiper section over.
    When I messed with this I didn't notice a difference between the '98 and '95 so initially thought the were identical. Swapped the mounting plate and put the '95 motor in. The wipers wouldn't line up right (parked high and wiped the a-pillar) and for some reason I assumed the output shaft was not in the same position on the '95 motor since the wipers were slightly off. I'm pretty sure that assumption (dumb conclusion now that I think about it) was wrong, but I didn't have time to mess with it more that day. I believe the actual problem was the output shaft on the new motor was simply clocked slightly different.
    So looking through my new-to-me service manual I see that there is a wiper arm park position adjustment that can be performed on the wiper arms. If the '98 motor decides to stop parking correctly again (all the way up) I'll swap the '95 motor in and make this adjustment. I'll give it a try on the passenger side arm since it parks a little higher than the driver side arm as is.
    Yesterday I took apart the original '91 motor from The Ice Car to see the inner workings. Here's a picture of the gear.
  7. #47
    Nov 2012
    Shelby Township, MI
    3,238
    Intake and associated hardware ordered. Since I'm not driving much due to COVID-19 lockdown, and lucky enough to be still working from home, the money that I would normally spend on gas will easily pay for the purchase of this intake and parts.
    I ordered the updated PI coolant tube and nipple along coolant hoses, fuel injector O-rings, and other odds and ends from RockAuto. The intake I ended up ordering appears to be a PI intake that comes with the 1W7Z-9424-AAA kit with gaskets and alternator bracket. I'll have to look it over when it gets here and determine if I have everything I need or if there is anything I forgot. Since the original intake has no problems YET, I'll have time to procure whatever I forgot.
    Knowing now what you guys have said, looking over Ryan's writeup (http://www.grandmarq.net/vb/showthre...-Manifold-Swap), and watching the video ChrisFix did (https://www.youtube.com/watch?v=beSV_jZxR5o) has me confident that I can do this PI intake swap no problem... when this lockdown is over (I'll disinfect things as they arrive).
  8. #48
    Nov 2012
    Shelby Township, MI
    3,238
    Got an update on the manifold, shipping has been scheduled and, according to the FedEx tracking, it should be here by Saturday.
    All the stuff I ordered from RockAuto already arrived. I'll take inventory and order whatever else I need which shouldn't be much. I still need to investigate if I need to replace to coolant tube nipple or if I already have the right one, which apparently some '98s do. My build date is 01/98 so I'm hoping I have the later nipple and won't need to order a water pump gasket.
    I found some info that suggests I would need the later thermostat housing. It looks like in Ryan's writeup his pre-2001 housing was used no problem on his PI intake. So I assume my stock housing will be fine (as long as it is in good shape, which it should be at 65k miles).
    Washed the car yesterday and noticed more scratches that I didn't notice last time. They aren't new and not heavy scratches, I just didn't notice them before.
  9. #49
    19,404
    If the scratches bother you there is an easy way to make them less noticeable.
    Pick up some 1000 and 3000 grit sand paper (preferably the unigrit type that has a soft backing). You can find this easily inside of a headlight restoration kit that meguiars sells. Good to have anyways...
    Wet down your scratch and with little pressure sand with the scratch with the 3000 grit. The idea is knock down the high ridges of the scratch lessening the irregular gouges the light if reflecting upon. You then follow it up with some compound to brighten the paint back up after your wet sanding. You may not remove the scratch entirely but you will make it less noticeable.
  10. #50
    Nov 2012
    Shelby Township, MI
    3,238
    Intake arrived today.
    The kit I ordered, 1W7Z-9424-AAA from https://www.fordpartsgiant.com/ came with:
    Service Info sheet (1W7E-9E473-CC)
    Intake Manifold (1W7E-9424-AB on a sticker on the intake, 1W7Z-9424-AB per the Service Info sheet)
    Intake Manifold Gaskets (YL3Z-9439-BA)
    Alternator Brace/Bracket (1W7Z-10153-CB)
    Water Outlet Connection (Thermostat Housing) Bolts (W708309-S437)
    O-Ring For Thermostat (F1VY-8255-A)
    Part number on the bottom of the coolant crossover: 5W7E-8C368-AB
    Picture:
    Service Info Sheet
    http://www.grandmarq.net/vb/attachme...chmentid=53902
    Comparing the 2001 listing on the info sheet to the 1998-2000 listing there are a couple of extra items listed for 1998-2000.
    One difference is the Water Outlet Connector (Thermostat Housing) which the new thermostat housing requires the upper rad hose included in that kit.
    Since I'm fairly certain my stock thermostat housing will work, I think I'm set there.
    The other difference is that kit includes an engine cover and the stud and nut to go with it. I'll worry about that when I get there since it is not a critical part. If my stock engine cover can't be modified to work I'll source one that will fit the new intake, but not going to worry about it ahead of time.
    It's also interesting that the intake part number is different in that kit: F8AZ-9424-CB, which I assume is a NPI intake which is why I didn't order that kit.
    No idea when I'm going to get to this job. The stock intake is still fine, and I've been taking The Ice Car to the store the last couple times I ventured out, because why not take my apocalypse car, LOL.
    Side note on fordpartsgiant.com, I had no problem with them. There was a delay in processing due to COVID-19 (ordered at the same time I ordered the RockAuto items), but I was wondering if I was going to get any of this stuff this month, even from RockAuto, considering the current circumstances.
    Attached Files Attached Files
  11. #51
    Nov 2012
    Shelby Township, MI
    3,238
    Checked the coolant tube connection and it is the later style connection, so the water pump will not need to be removed. I'll swap the O-rings from the new nipple though.
    I had a chance to adjust the p-side wiper arm today. Very easy. It now parks where it should instead of a couple inches high. D-side was already good so I left it alone.
  12. #52
    Nov 2012
    Shelby Township, MI
    3,238
    I now have all the parts I need for the intake swap. Now I'm just needing a place to work since I'd rather not work on this in my driveway.
    I also received more parts from RockAuto the other day. Shocks for all 4 corners and new springs for the rear. I'm definitely not doing this job in my driveway so might as well do it all the next time I get to one of my preferred working on car places (parents place or a friends place).
    KYB 344081 front police shocks, and in the rear Gabriel HiJackers 49205 with MOOG CC817 cargo coils. The springs probably don't need to be replaced but I don't like how the stock springs sit, and I thought a whale might look strange with CC819 coil springs like The Ice Car has so I decided to try the CC817. Other than the springs it's the same setup as The Ice Car.
    Also been cleaning the car when I have the time. My latest cleaning session, this past weekend, was seats (again). The rear look good enough that I didn't touch them again, but the front, especially the driver seat, needed another cleaning session. I'm using Lexol cleaner and conditioner. The first session was a slight learning session and got some of the easy nastyness cleanned off. Second, most recent, session was mostely the driver seat and working dirt out and conditioner in with a toothbrush. I found a picture from the day after I bought the car to compare to a picture I took today. I wasn't sure how much progress I have made but I can see it in the pictures. I figure I'll get these seats looking better little by little with each session.
    Before:
    After:
    Attached Thumbnails Attached Thumbnails IMG_20200301_164039566_HDR.jpg   IMG_20200424_184245534_HDR.jpg
  13. #53
    Nov 2012
    Shelby Township, MI
    3,238
    Oh, I almost forgot, I also did a little polishing of my wheels last weekend.
    I found a (dirty) picture from the day after I bought it and took a picture today for comparison.
    I also rotated the Before picture for easier comparison to the After picture. I wish I would have washed the wheel in the Before pic for a more accurate comparison, but I didn't know at the time that it would be a comparison picture.
    This is the worst looking wheel of the 4. I was able to work out some of the scuffs. Notably the scuff line just inside the wheel lip that goes from about 11:45 to 4:30.
    I used some 3000 grit sand paper like Dave had suggested on the paint scratches. I didn't want to get to crazy on the clear coat so some of the deeper curb scuffs are still there. I figured I would rather try my hand at scuff removal on the wheels first, and think I have worked up the courage to try it out on the paint on some of those light scratches.
    Before:
    After:
    Attached Thumbnails Attached Thumbnails IMG_20200301_164412925_HDR-rotated.jpg   IMG_20200419_161430246_HDR.jpg
  14. #54
    Looks good bro!
    How bad are the scuffs in the paint? I too was afraid of ruining the paint on my 02 gt when doing some paint correction for the first time but it seems to be pretty idiot proof lol. A little rubbing compound on the deeper stuff followed by polish works wonders. Even having to wet sand is easy. Just keep the area soaked and use even pressure. When it dries itíll look bad but thats because it needs to be followed by compound and polish. I wish I had some pics of when I wet sanded my 02 gt but I didnít take any befores.
  15. #55
    Apr 2010
    Southern NJ
    2,691
    I always liked those teardrop wheels. Look good! If you have some stubborn stuff on the leather you can use a Magic Eraser... BUT just go really lightly with it to make sure you don't damage anything.
    My new Volvo has white seats and my son really scuffed the back seat and the Magic Eraser took it right off.
    Past Panthers
  16. #56
    Nov 2012
    Shelby Township, MI
    3,238
    Looks good bro!
    How bad are the scuffs in the paint? I too was afraid of ruining the paint on my 02 gt when doing some paint correction for the first time but it seems to be pretty idiot proof lol. A little rubbing compound on the deeper stuff followed by polish works wonders. Even having to wet sand is easy. Just keep the area soaked and use even pressure. When it dries it’ll look bad but thats because it needs to be followed by compound and polish. I wish I had some pics of when I wet sanded my 02 gt but I didn’t take any befores.
    Thanks.
    There's a couple of spots that would require paint, but most of the scratches are very light and could easily be taken care of the way Dave described. Especially the scratches on the trunk lid that I didn't even notice until the 2nd or 3rd time I cleaned the car. Overall the paint is in really good shape for 22 years old. Hard to tell the difference between the 22 year old paint and the 2 year old paint on the driver side fender (and hood?).
    Quote Originally Posted by tjc78 View Post
    Thanks, these are definitely easier to clean and maintain than turbines and, as you said, they doo look good. I almost picked up a set from the JY a couple years ago. They were on a clearly garage kept car and looked every bit as good as this set. I decided against it since I needed wheels for snow tires and ended up getting a full set of '98-'02 steelies for the snow tires.
    I had a little practice with the sanding over the past couple of weeks. I started out with a dull scratched up pocket knife then moved to a not very good shape turbine wheel I had in my shed. The knife turned out great, the turbine not so much. Will definitely need some media blasting to make the turbine wheel decent, which I don't plan on doing any time soon. The point was to make a learning experience out of it, and I did learn bit while experimenting with 180, 800, 2000, and 3000 grit as well as a dremel and wire wheel.
  17. #57
    19,404
    Wheel did clean up good.
    Drive on over Ill go over the car for you and we can knock it out. I have everything needed.
  18. #58
    Nov 2012
    Shelby Township, MI
    3,238
    LOL, that would be awesome. Also quite the drive from the Detroit area. A doable drive, but not in the cards any time soon.
    My 303 Fabric Guard arrived yesterday. It for marine fabrics, but I figured it would work well on the canvas top.
    Read through the application instructions. Fully cures within 12-24 hours depending on conditions such as application pattern and temperature.
    Application temperature is recommended at above 70F in direct sunlight for quickest curing. I'll have to keep an eye on the weather forecast to pick a day where the following day will also be dry, and I don't plan to drive the car, so that it has plenty of time to cure.
    I did a very small test patch (maybe a couple square inches) below the rear window above the trunk lid. So far no weird discoloration, color running, or anything other ill effects. I'll probably get to this next weekend if the weather will cooperate.
  19. #59
    Nov 2012
    Shelby Township, MI
    3,238
    Whale trunk lighting (at least '98) sucks very much.
    I had a spare damaged trunk light harness sitting around. It's the original from The Ice Car which got pinched which resulted in the wires being cut. I figured that one out then the trunk randomly opened in a parking lot leaving from Meijer one day.
    Anyway, I installed this in the trunk lid last week after noticing how badly the stock lighting sucks anywhere other than the area directly below the stock light. I finally got around to connecting the wire today. I still need to drill a hole and install the screw so the housing grounds consistently.
    The box light is very much superior.
    Before:
    After (now you can see all that junk in the trunk):
    (Looks like I lowered the image quality more than I thought, oh well, it saves drive space and still get the point across.)
    Attached Thumbnails Attached Thumbnails IMG_20200428_172153143.jpg   IMG_20200428_213135320.jpg   IMG_20200428_213117261.jpg
  20. #60
    Riding on air! mercurygm88's Avatar
    Jul 2011
    The Firelands
    1,346
    Before:
    Interesting. Maybe it is a '98 thing? My LSE has two bright lights one in the trunk lid and one at the bumper side of the trunk, lights the whole thing up. Both my '01 and '03 Town Cars had good trunk lighting as well.
    2002 Mercury Grand Marquis LSE - Purchased 02/19/20 at 96,500, current Daily Driver.
    2003 Lincoln Town Car Signature Series - Purchased 07/29/19 at 69,500, sold 2/14/20 at 85,500.
    2001 Lincoln Town Car Executive Series - Purchased 04/18/15 at 108,653, traded in 05/02/16 at 139,000.
    1995 Mercury Grand Marquis GS - Inherited 10/2009 at 105,000 totalled 4/30/10 at 120K, My dumbass fault.
    1988 Mercury Grand Marquis LS - Purchased 6/26/11 at 82,610 totalled 4/16/15 at 137,000, Not my fault.
