I have tried "googling" this with no luck. Does anyone know the gallon per hour consumption for the 4.6 running through various RPM? I have seen these descriptions for various boat motors.
Gph / rpm
It isn't linear, I can tell you that much. Engine load in a given gear would play the most important factor IMO. But then you can elaborate on that with the things that affect it, such as tire pressure, road grade, load, engine health ect ect.1985 LTD Crown Victoria - SOLD
I want a rough range so i can calculate the GPH vs MPH and see if there is a big difference when cruising 55 or 65mph. I know with boat, i found a website that will show rough GPH at different RPMs. I use that value to decide what RPM to cruise at after I plane so im not dumping fuel in the bay
68-72 netted my best MPG with dual exhaust and 2.73 rear gears. The 4.6 does pretty good for economy when kept between 1500-1900 RPM.
Of course load, terrain, gearing, and mechanical condition are major factors.
I don't suppose your model has the instant fuel economy readout? Thats the easiest way to tell. Failing that if its new enough for obd2, even a cheap bluetooth scan tool and free software on your phone should be able to give instant fuel economy to see what the most fuel efficient cruise speed is.86 Lincoln Town Car (Galactica).
Found some info about it... https://stackoverflow.com/questions/...bd2-parameters
As stated, if you have a 96+ model, you can use an OBD-II bluetooth adapter and Torque Lite, OBD Fusion, or similar FREE app to show instant fuel economy values reported by the PCM.
Also, this is the cheapo OBD-II adapter I use and it works like a champ. https://www.amazon.com/gp/product/B00PJPHEBO/
Originally posted by DonLawson84 View PostMy car does not have the read out. I also did not realize OBD2 bluetooth was so cheap. I will have to pick one up, thank you for the link
Another idea is to utilize a vacuum gauge and monitor vacuum at different cruising speeds. Higher vacuum nets you better fuel economy. Also a standard tripminder from the 80s models will also wire up but not really any place to put it. Assuming the car in question is not a 98+ towncar and is pre 2006 vic/grand marquis.
