Ac Compressor Clutch Coil
    Does anyone have the part number for just the coil? I’ve found a few on ebay with the right connector but have a few different part numbers. Are they interchangeable? I’m sure a few of you remember how my belts keep jumping and cut into the clutch coil connector. Well installing the smog pump seems to have eliminated that problem but the connector is in poor shape.
    I took to car on Valentines day and the ac worked for hours then the compressor kept shutting off until it quit altogether. I thought the worst but after some snooping around it seems that once it gets hot the compressor shuts off until you wiggle the harness.
