To much fuel
    I think so. E0AZ-7F330-A is the listing for the TV rod cars. I can't actually find anything for the cable cars. My master parts manual pre-dates the bronze bushing service part I think.
      An update, the bushing was right, the car seem to run ok, but i had it stall on me slowing down to go around a corner at about 10-15mph off the gas and brake, i think i fixed a big vacuum leak with the headlights, i switch a green and blue line around at this wierd box under the dash has 3 lines going in( green, white and blue) white being the source.
          Also i dont know if its possible, but one headlight cover is missing a bushing so it so its loose and crooked, unobtanium?
            Kishy probably knows more about the headlight controls on a Mark VI than anyone here. He's done some writups on the various bits of the system.
              Im going to try plugs (never did them oops) and cut the cat out to see if that helps any, has anyone on here attempted a 4.6 swap in one of these, ive been thinking about it
              Edit, the guy before me ran it super rich and so did i for a while, oops, i i think the cat may be plugged
                I'd carb swap it before I put a 4.6 in, but i have no interest in the modular engine. I'm also not a carb guy so that says a lot.
                  Originally posted by 82EmilioPucci View Post
                  Has anyone on here attempted a 4.6 swap in one of these, I've been thinking about it.
                  Yes, one member has swapped a 4.6 into a box body. Another member has swapped a box coupe body onto a newer Panther chassis. That was a big job!
                  '79 Continental Town Car
                  '90 Crown Victoria LTD
                  '94 Crown Victoria
                    Search for "modbox"
                      That job looks like something id be down to tackle, thats is the 4.6 swap, not that frame stuff! Is there a year of 4.6 i should say away from, ive heard early ones have valve seals and something about 04s, and i want the obd 2 as the guy who did this before, i like the plug and play stuff, would 99 to 03 be the best range?
                        I may be able to get a 08 or 10 for cheap(wrecked) is there more security in those, or other disadvantages to the newers ones, and should i make a new thread in a different location?
                          ‘01+ would be best since they feature the Performance Improved cylinder heads. You could use a ‘96-‘00 engine, but it wouldn’t be as snappy in stock form. The ‘91-‘95 engines are the ones known to have the oil burning issues with the original valve stems.
                          If you’re going the 4.6, I’d just look for the lowest mile one you can get that meets your criteria. You’d also need to grab the whole wiring harness for the engine and transmission from the donor car.
                            Ya im going to try and get a whole car, do the newer ones have any like drive by wire stuff or anything that would stop me
                              '05+ is drive by wire.
                                The wrecked 06(thought it was an 8) had 300,000miles lol so i need a 01 to 04 sounds good
