Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: To much fuel
    PimpDaddy 82EmilioPucci's Avatar
    Jun 2019
    Albia, Iowa
    79
    Default To much fuel
    My 82 continental is getting lots of fuel, and i was wondering how to test the map sensor and the coolant temp sensor. Also if anyone else has any suggestions. Fuel regulator has been replaced and injectors cleaned and tested pretty good
    5,805
    Not familiar with EEC III but here’s a couple things:
    On the ECT - assuming it’s the same as the later ones, check the resistance between the two pins compared to the resistance values found at the bottom of this webpage: http://www.myo-p.com/Ford-EEC/EEC%20...e%20Sensor.htm
    On the MAP, you might be able to unplug and see if the system defaults to a usable value that makes the car run but maybe not run well. Should be enough to tell you if it’s the problem or not.
    39,547
    I'm also not real familiar with EEC-III. Beyond making sure you have vacuum at the MAP and no vac leaks, what might help is picking up an engine and emissions diag manual. That will have specific test procedures by symptom for all sorts of problems.
    https://www.ebay.com/itm/1982-Ford-C...0AAOSwg0debXS4
    for 14 bucks its not a bad thing to have.
    Jun 2019
    Albia, Iowa
    79
    I unplugged the connecter to the coolant temp sensor and the map sensor, it ran poorly when i did both, i was wonder is my egr valve could be the issue, also i do have those books around here somewhere
    39,547
    if the EGR is stuck open it will run all kinds of messed up. I think 82 has a cooler under the valve. Would be worth pulling that to make sure the valve can completely close and verify its not getting vacuum with the engine running.
    Jun 2019
    Albia, Iowa
    79
    Just got time between saving a corvette and buying my 94, was looking for bad vacuum hoses and the second picture that isnt the tv cable bushing is it? And the first picture thats the egr cooler and on top is the egr valve right?
ID:	53907   Click image for larger version.
    5,805
    Yes and yes.
    It looks like your TV bushing is missing. Need to get one quick! I would not drive it without a bushing in there, or at least wired up so the rod doesn’t fall off the stud. https://www.ebay.com/itm/FORD-MUSTAN...EAAOSw~vpZ~h8U
    Jun 2019
    Albia, Iowa
    79
    Alright sweet the car wont be moving for awhile, i ordered that bushing, and hope maybe that egr valve/ cooler is the problem miss drive that car!
    Jul 2019
    Finland
    499
    You can check if your EGR valve is getting vacuum properly by putting a vacuum gauge on the vacuum line from the EGR solenoids.
    If you have a similar EGR setup as me, the EGR is controlled by 2 valve cover mounted solenoids, control & vent:
    They are the 2 middle ones and look like this:
    I'm holding the line to the EGR valve.
    If you suspect the EGR valve, you should take it off and test if it's sticky or leaking. I found easiest to spray carb cleaner or whatever into the larger port and see if it leaks past the piston.
    When you get your TV bushing in place, you could go for a drive with the EGR valve unhooked, the line plugged and the EGR solenoids unplugged. If you car is running that bad, were it the cause, it should make a difference.
    1985 Mercury Grand Marquis LS
    1997 Volvo 850 GLE Estate
    Jun 2019
    Albia, Iowa
    79
    Got the cooler and egr valve off, egr valve moves freely and no brake clean comes out the valve, on the cooler brake clean goes in on side and come out the other.
    39,547
    are the vacuum lines to the MAP good? Does the EGR get constant vacuum when the engine is running? It should not.
    Jun 2019
    Albia, Iowa
    79
    I do have vacuum to the map and the engine ran worse when unplugged, ill get everything back together and check for vacuum at the egr, on start while idle it should have 0 vacuum?
    39,547
    correct, 0 vacuum at idle.
    Jun 2019
    Albia, Iowa
    79
    It has no vacuum at idle, for a better example of what it does, it will drive fine down the highway, then sometimes stalls a stop signs (the fuel regulator fixed most of the stop stalls) and in reverse it like to stall out
    21,751
    The bushing for the EFI cars is the same one for the carb/CFI cars?
    39,547
    I think so. E0AZ-7F330-A is the listing for the TV rod cars. I can't actually find anything for the cable cars. My master parts manual pre-dates the bronze bushing service part I think.
    Jun 2019
    Albia, Iowa
    79
    An update, the bushing was right, the car seem to run ok, but i had it stall on me slowing down to go around a corner at about 10-15mph off the gas and brake, i think i fixed a big vacuum leak with the headlights, i switch a green and blue line around at this wierd box under the dash has 3 lines going in( green, white and blue) white being the source.
    Jun 2019
    Albia, Iowa
    79
    Jun 2019
    Albia, Iowa
    79
    Also i dont know if its possible, but one headlight cover is missing a bushing so it so its loose and crooked, unobtanium?
    39,547
    Kishy probably knows more about the headlight controls on a Mark VI than anyone here. He's done some writups on the various bits of the system.
Tags for this Thread
