Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 52
Thread: To much fuel
  1. #21
    PimpDaddy 82EmilioPucci's Avatar
    Jun 2019
    Albia, Iowa
    90
    Im going to try plugs (never did them oops) and cut the cat out to see if that helps any, has anyone on here attempted a 4.6 swap in one of these, ive been thinking about it
    Edit, the guy before me ran it super rich and so did i for a while, oops, i i think the cat may be plugged
  2. #22
    39,660
    I'd carb swap it before I put a 4.6 in, but i have no interest in the modular engine. I'm also not a carb guy so that says a lot.
  3. #23
    GMN Regular
    Mar 2008
    Fredericton, N.B. Canada
    12,550
    Quote Originally Posted by 82EmilioPucci View Post
    Has anyone on here attempted a 4.6 swap in one of these, I've been thinking about it.
    Yes, one member has swapped a 4.6 into a box body. Another member has swapped a box coupe body onto a newer Panther chassis. That was a big job!
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
    You may regret selling it. Think it over.
  4. #24
    21,802
    Search for "modbox"
  5. #25
    Jun 2019
    Albia, Iowa
    90
    That job looks like something id be down to tackle, thats is the 4.6 swap, not that frame stuff! Is there a year of 4.6 i should say away from, ive heard early ones have valve seals and something about 04s, and i want the obd 2 as the guy who did this before, i like the plug and play stuff, would 99 to 03 be the best range?
  6. #26
    Jun 2019
    Albia, Iowa
    90
    I may be able to get a 08 or 10 for cheap(wrecked) is there more security in those, or other disadvantages to the newers ones, and should i make a new thread in a different location?
  7. #27
    Nov 2014
    Evans, GA
    1,653
    ‘01+ would be best since they feature the Performance Improved cylinder heads. You could use a ‘96-‘00 engine, but it wouldn’t be as snappy in stock form. The ‘91-‘95 engines are the ones known to have the oil burning issues with the original valve stems.
    If you’re going the 4.6, I’d just look for the lowest mile one you can get that meets your criteria. You’d also need to grab the whole wiring harness for the engine and transmission from the donor car.
    -1997 Grand Marquis LS (222K Miles) - The Daily Workhorse & March 2015 + January 2019 POTM Winner
  8. #28
    Jun 2019
    Albia, Iowa
    90
    Ya im going to try and get a whole car, do the newer ones have any like drive by wire stuff or anything that would stop me
  9. #29
    Nov 2014
    Evans, GA
    1,653
    '05+ is drive by wire.
  10. #30
    Jun 2019
    Albia, Iowa
    90
    The wrecked 06(thought it was an 8) had 300,000miles lol so i need a 01 to 04 sounds good
  11. #31
    Jun 2019
    Albia, Iowa
    90
    Im pretty sure ive got a car lined up 2001(i think) cv with 90k. I think the car would be badass with a floor shifter from a cv mgm or mm, ive got a lead on a console, but i had a question if anyones ever tried a lincoln continental shifter assembly in the panther console, they look the same but have different part number
    Cv part number 1W3P-7K004-ADW
    Continental number f80p-7k004-aaw
  12. #32
    Jun 2019
    Albia, Iowa
    90
    If anyone was wondering, the only difference i see in the continentals dont have a o/D button, but the 1999-2004 mustangs do so the shifter would need swaped
  13. #33
    Jun 2019
    Albia, Iowa
    90
ID:	54841   Click image for larger version.
  14. #34
    19,426
    Sneaky. I like it.
  15. #35
    Jun 2019
    Albia, Iowa
    90
    The car had trouble idling recently, I smoke tested some vacuum stuff again and was wondering if the egr vacuum valve solenoid should be leaking when car is off, also 2 other solenoids right behind the map sensor were leaking as well. Like out of the top
  16. #36
    39,660
    they should not be. Wonder if someone connected them wrong. If you put vacuum on the wrong side it will pull through the vent tube.
  17. #37
    Jun 2019
    Albia, Iowa
    90
    All the lines look factory, they are all color coded, I only notice them because they have a vent on top and when I smoked it, they had baby oil bubbling on top of them(my smoke machine uses baby oil).
    Can I bypass them? The egr one is 40$, I didn't know/ check the other 2
  18. #38
    Jun 2019
    Albia, Iowa
    90
ID:	54856 i got one, needs a little work, but these things are harder to find than I thought
  19. #39
    39,660
    strictly speaking you can remove vacuum from them all. It will keep the EGR from working and probably the smog pump stuff. The MAP sensor has to have vacuum on it.
  20. #40
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,303
    That anti theft cover plate is really cool. What brand of new stereo did you get ?
Tags for this Thread
