Page 3 of 3 FirstFirst 123
Results 41 to 52 of 52
Thread: To much fuel
  1. #41
    PimpDaddy 82EmilioPucci's Avatar
    Jun 2019
    Albia, Iowa
    90
    Its a pioneer avic x710bt, got it from a junk jeep. It pretty nice
  2. #42
    Jun 2019
    Albia, Iowa
    90
    The map sensor get its vacuum from a big brass colored vacuum thing, I think its called a diaphram? The 2 solenoid are just behind it, I think they are for the smog pump as well
  3. #43
    39,665
    MAP should have a line running directly to the manifold.
    The other two are probably smog pump, but could be EGR. I don't know exactly the layout on the early cars but following the hoses will confirm. Some early stuff used 2 solenoids to run the EGR, one applied vacuum to open the valve and the other is the vent to let it close again. Later ones did both functions with a single solenoid.
  4. #44
    Jun 2019
    Albia, Iowa
    90
    I got what was going to be the parts car and decided I like it to much. Its a 2001 crown Victoria with 92,000 miles. So I might be looking to get rid of the 82 mark 6
  5. #45
    Jun 2019
    Albia, Iowa
    90
  6. #46
    Jul 2019
    Finland
    532
    Quote Originally Posted by 82EmilioPucci View Post
    Plans go out the door sometimes, you should probably throw those doors out the door while you're there
    1985 Mercury Grand Marquis LS
    1997 Volvo 850 GLE Estate
  7. #47
    39,665
    Multiport inject the 302. It'll be fine.
  8. #48
    Jun 2019
    Albia, Iowa
    90
    Ya the vic needs some doors lol, and I have too many cars lol 4 is a good number, 5 ehhh
  9. #49
    Sep 2014
    Warren, MI
    6,063
    What gadget said. If only your '82 had two fewer doors.
  10. #50
    Jun 2019
    Albia, Iowa
    90
    The 01 crown vic is having some issues, today it had a very long crank, 10 sec then a 5 sec, after it got ran below a quarter tank(not my doing) it doesn't seem down on power, but it could be, I haven't had a pressure gauge on it yet. This was the next day after filling it up. Is there a check valve or regulator I can check?
  11. #51
    39,665
    might want to start a separate thread for that, easier to keep track of. I believe the check valve is built into the pump though.
  12. #52
    Jun 2019
    Albia, Iowa
    90
    Ya i was thinking that lol
Tags for this Thread
