New 2009 owner
    New 2009 owner
    Hi all
    I'm enjoying puttin mods on my GM so far trans pan with oil plug, new speakers new head unit not done yet because I can't find the VSS hookup. Sub and amp, considering headlight mods, windows tinted. Changed all fluids and put in double iradium plugs. Considering a duel exhaust.
    Jim
    PS need a wiring diagram.
    Welcome to the forum Jim
    Last name Duke?
    I am close with a Duke family here in New York. Actually the owners of my company.
      VSS hookup for your headunit? You usually can do without it.
      Is the head unit not allowing video because it’s not hooked up? Check out the web for information on your particular unit. Most have a bypass you can do to avoid the VSS wire.
      Past Panthers
        Last name Duke?
        I don't know any Duke's in New York but have done some serious ancestry an my connections come from South Carolina then to the old U.K. to Cum Lake. Then back to Norway. If the Duke you know has blue eyes they likely came through the United Kingdon via Norway.
