Page 39 of 42 FirstFirst ... 293738394041 ... LastLast
Results 761 to 780 of 830
Thread: My '85 MGM, "Maisa"
  1. #761
    41,321
    depends how its made. The original for my Conti looked like the original off his car, but it wasn't held together with a snap ring. They used a solid post that was swaged over on the back side to capture it, more or less like a rivet head. I had to grind the swage off the back side so I could get the post off and evict the junk pulley. Once that was done I drilled through it so I could use a bolt with a locking nut to hold it back together and fit a standard idler pulley on there. Looks slightly goofy but tensioner assemblies for that car just do not exist, and now it uses a common $25 off the shelf idler.
  2. #762
    Jul 2019
    Finland
    1,331
    I've ran through a tank of gas with the current jetting. A bit around town, most of the time cruising around 50 or 65 mph.
    Fifteen miles per gallon, not a damn drop more. Just like with the CFI. At 14 AFR on cruising speed, obviously not ideal, but I would've expected a bit better.
    Seeing folks get even 20 MPG and beyond driving way faster than that makes me question if we're even driving the same cars.
    The tensioner pulley is that bit smaller so I could fit the AC belt above or under the tensioner. If I route it above the pulley, it's easier to install and tighten plus the tensioner would be on the longer stretch of belt, but the belt pulls down on the tensioner, which might bend the new one like the previous. The factory way would be better for the tensioner bracket but it's complete ass to tighten the belt. I can't find a stubby 3/4" square drive extension anywhere...
    Also in heavy rain and higher speeds the driver side wiper still smacks the A pillar trim. Less rain and speed and there's like 2 inches of gap... Worn out much?
  3. #763
    41,321
    With the stock engine in my car doing a fair bit of highway it never broke 15 mpg. With all the stuff that I've done over the years, its like 18 mpg on the highway at best. I've driven other people's cars and gotten 20, and they drove my car and got 17 so its not just my driving. Some of these things are just fuel misers for reasons I cannot explain.
  4. #764
    all the CFI are belong to me
    Feb 2014
    Windsor, ON, Canada
    2,279
    My Lincoln does this. I'm pretty sure it's excess play being allowed by a crack in the assembly that holds the shaft for the driver wiper arm. Haven't been able to identify it positively as that, but it's my current theory.
    Current driver: 84 TC
    Panthers, Parked: 83 GM 2dr | 85 CS | 86 GM | 88 TC | 91 GM
    Not Panthers: 85 Ranger | Ranger trailer | 05 Focus
    RIP: 97 CV | 83 TC | 04 Focus | Junkyards
  5. #765
    Jul 2019
    Finland
    1,331
    Got the tensioner and belts back on, aswell as the smog pump bolt with a "spacer" (aka wheel nuts).
    One casualty though...
    The tensioner pivot bolt didn't feel like tightening, I feel around backside and a piece falls on my hand.
    The AC compressor ear cracked off... The threads are fine, there's no gap between the ear and accessory bracket, I guess the compressor ear didn't want to keep going. Nut and bolt fix, not ideal but it'll work.
ID:	57902 Click image for larger version.
    I did also clean up the AC bracket, I guess it wasn't painted black from the factory.
ID:	57904 Click image for larger version.
    Belt's doing a teeny tiny sqeaky sqeak as I moved the car a bit in the driveway, but hopefully it'll go away, water or something. Belts are tight.
  6. #766
    41,321
    If its slop in the joints of the wiper linkage I think you can fix that with the same kit they use for Mustangs.
    https://www.cjponyparts.com/windshie...2004/p/HW1805/
    if its the part where the wiper arm itself attaches thats cracked there isn't a part available for that. Someone on here drilled that whole thing apart and rebuilt it with JB Weld if I remember right.
  7. #767
    Jul 2019
    Finland
    1,331
    The slop seems to be somewhere in the middle of the cowl area, the splined shaft and connections around it are pretty tight.
  8. #768
    41,321
    that'll be the connector things then. The motor crank connects to a bar that ties into the bar between the two pivots roughly in the middle of the windshield.
    Mine had problems in both the connector and the pivots were cracked so the whole spline part wobbled around. Basically every part of the linkage was f'd to the point that I had to drive with my hand out the window as a stop otherwise the wiper would jump off the glass. Couldn't index it further down or it would bind down at the bottom where I couldn't reach it. All that BS stopped when I replaced the transmission.
  9. #769
    Jul 2019
    Finland
    1,331
    -I was able to adjust the driver side wiper another notch down, it parks kinda far down, but probably won't break itself.
    -Got the old pulley removed from the tensioner & bearing, too bad my hammering fcked up inside lip some. The bearing is metric, to my surprise.
    -Bought #59 jets for the primaries and #58 jets for secondaries, I'll install them before friday's cruise night.
    Also I filled the tank, 161 euros...
  10. #770
    41,321
    Metric bearings have been a standard for many decades. Inch bearings are actually pretty uncommon even on 'murica-made stuff from the days when only the dirty Commies did things in metric. My 1957 South Bend lathe uses them.
    uses what, a 6202 ?
  11. #771
    Jul 2019
    Finland
    1,331
    uses what, a 6202 ?
    It's a 6203. Dunno why I thought of imperial sized bearings, I guess the car is a mismatch of metric and imperial units so why not the bearings too.
  12. #772
    Jul 2019
    Finland
    1,331
    New jets are in, we'll see how the mixtures settle now. Hopefully the cruise is close enough to call it good for real.
    Also cleaned up the vacuum lines to and from the charcoal canister. I've had the tank vent line just open now, but now it should breathe freely but via the canister.
    I've got a full tank, but I don't feel like driving much at all. Regular E10 gas is at 2,5€/l or $10 per gallon...
    A basic cruise night is about 30-40 euros just in fuel.
    Fuel prices, general melancholy and my new job getting me super exhausted mentally = me not having a particularly good time.
    I'm currently fixated on trying to figure out what the fuck I'm supposed to do at work and wanting a new daily driver.
  13. #773
    Jul 2019
    Finland
    1,331
    Well, going from #61 to #59 main jets was a bit too much, low throttle cruising afr spends a bit too much time at 16.XX and at higher speeds it's kinda close to 16 afr aswell. I haven't experienced any negative effects of the lean mixture, but I want to play things safe(r). I got these afr readings at around 10°C, so it would richen up a little bit with warmer weather. I think I'll pop in some #60 jets in the primaries and call them good.
    WOT is around 13,5 AFR, so I could probably richen it a bit aswell for "optimal performance". Maybe I'll replace the current #58's with the #59's which are currently in the primaries.
    Idle is weird, speed and mixtures vary from time to time. Every intersection had a different afr, sometimes 13,5, sometimes 14, 14,5 or 15.
  14. #774
    41,321
    make sure the throttle is closing correctly. If the linkage is binding a little bit, sometimes it may be ever so slightly into the transfer slots and making it seem fat at idle.
  15. #775
    Jul 2019
    Finland
    1,331
    It would seem that the lean running has some noticeable effects afterall. Yesterday I had 130 miles on the trip odo and the gas gauge still showed half a tank! Usually I'm seeing half a tank at around 100 miles on the odo.
    Friday's cruise night included mostly highway driving around 50-65mph and yesterday was mostly puttin around town and backroads at 35-40mph.
    Still, it's too lean to be absolutely safe, so I'll get another set of jets next week.
  16. #776
    41,321
    If you get the timing to advance more it does a better job of running on the lean side. Still have to ride the line between lean economy and lean damaging the engine.
  17. #777
    Jul 2019
    Finland
    1,331
    Yeah I've been reading more into running carbs lean, it's quite interesting. I've read about Chrysler's Lean-Burn and some more of other lean cruise systems. I believe the current mixtures I'm having are safe for the most part, but I need more time behind the wheel to make sure it's not too lean when it's under more load. Only issue I'm really having is the occasional lean surge at cruising speeds. I've got to pull a couple plugs some day here to check they're not getting burnt. Also I've read that lean burn isn't particularly good for 3-way catalytic converters.
    I have no idea how much the stock Duraspark distributor advances at low RPM, but probably not too much to be worried about detonation, since pressing down my foot even slightly more gets the mixtures to safe levels immediately.
    Getting a Holley Sniper or MPFI with full spark control and leaning out cruise would be an interesting experiment.
    Still going to get the +1 main jets to hopefully get rid of the lean surge and keep the cruise afr from going too much above 16 AFR.
    Also today I sent most of the CFI stuff over to Germany for @hillbillycat to enjoy.
  18. #778
    41,321
    if you're getting the surge, it needs at least a little more fuel.
    The D-spark depends on which plate is in there. They all have 2 notches, and there are a couple different plates, so you'd have to take it apart and see which plate is installed and which way its installed. That just sets your advance limit. How soon it comes in is done with the springs.
    Honestly thats one place the HEI distributor has it all over the Ford units. All that crap is right on top, easy to muck with. The Ford ones you have to take the whole thing off. Basically like filling a cavity through the rectum.
    http://www.reincarnation-automotive....ons_index.html
  19. #779
    Jul 2019
    Finland
    1,331
    Hmph...
    The difference in AFR between #59 and #60 jets is much bigger than #60 and #61.
    Cruising afr is now where it'll stay I think, not as lean anymore, pretty close to stoich, leans more to rich side on fluctuations.
    Now what really bugs me is that 70kmh/45mph bucking at light throttle. It also does it at around 100kmh/62mph. So around the same RPM and throttle position?
    It's bad and it's kinda undrivable when it starts bucking. Gotta let off the gas or press it more.
    AFRs seem fine during the bucking. Could not enough timing cause that?
    I've also come to the conclusion that the front cig lighter is super slow for phone charging, or my charger is just shit.
  20. #780
    Sep 2014
    Warren, MI
    6,790
    Check for vacuum leaks or fatten up the main jets and see if it goes away. If it goes away from the extra fat, I'd suspect what gadget was saying about the transfer from the idle circuit to the primaries. What vacuum point is your power valve set to open at? Because another thing you could check is to see if when you notice the surging, you also see fluctuation in manifold vacuum. Could be that it's dropping off, the power valve opens, fattens things up, vacuum picks up and then it closes, gets lean again and then the process repeats. My two dimes worth.
