Page 27 of 29 FirstFirst ... 172526272829 LastLast
Results 521 to 540 of 569
Thread: My '85 MGM, "Maisa"
  1. #521
    Jul 2019
    Finland
    1,128
    I'm still going through my list of everything to do for the carb swap... Does the CFI choke heater power wire work the same as with a normal carb electric choke? Or is it timed by the ECM somehow?
    Also thinking about giving the engine bay a little bit of spruce up.
    How about gold valve covers and air cleaner like in the early 60's? Not really feeling the ol' Ferd Blue...
    2008 BMW 530d Touring, "Femma"
  2. #522
    Dec 2021
    185
    Personally, I prefer the Ford Blue but if that doesn't work for you, the Gold looks spiffy!
  3. #523
    Sep 2014
    Warren, MI
    6,647
    I'd wager the choke pull-off power wire works the same way as a regular carburetor. The ECM didn't do much in '85.
  4. #524
    GMN Regular
    Aug 2018
    839
    Derek nailed it. The wiring for the choke pull off goes straight from a stud on the back of the alternator to the choke. Be warned, it will only work with the one stud though.
  5. #525
    41,002
    You need to know what voltage the choke heater expects. The stock system runs around 8 volts or so using the S (stator) terminal on the alternator. If the carb's choke heater wants 12v, that will cause it to either not open or take a very long time to open.
  6. #526
    Jul 2019
    Finland
    1,128
    Hmmm. Holley says the electric choke needs 12 volts. So the Stator post is only 8v?
    Holley states:
    Connecting the choke cap to the ignition or ignition coil could result in unacceptable choke operation, poor fuel
    economy, and possible engine misfiring, since the voltage delivered to the spark plugs will be severely reduced
    by the drain imposed by the choke cap.
    So I'll have to figure out another 12v source. I guess I'll repurpose the EEC relay for the fuel pump aswell as the choke.
  7. #527
    GMN Regular
    Aug 2018
    839
    If Iím not mistaken the stator on the back of the alternator puts out ac not dc. Thatís why itís only 8v instead of 12v.
  8. #528
    Jul 2019
    Finland
    1,128
    Kinda hard to make any sense of it. Holley says use switched 12 volts. On forums there's as many people screaming that the stator post works and just as many saying it doesn't...
    Main point is that the stator post's 8 volts would open the choke very slowly.
  9. #529
    Sep 2014
    Warren, MI
    6,647
    I love stuff like this, why things which should only take hours end up taking weeks. Well, if you want it done right.
  10. #530
    Mar 2006
    Bedford, VA
    6,576
    I used the stator post on the Edelbrock on the Rustang. Google says it needs 12V. It works fine on stator. May have to turn the cap a notch or two lean if you have any issues, but I think it will work fine otherwise.
  11. #531
    Mar 2010
    Lewisville, TX
    22,746
    colder climates may want a slower open anyhow. So there's that.
  12. #532
    Jul 2019
    Finland
    1,128
    Cold weather isn't really a concern, since she's just a summer cruiser. So far it's been from ~April to October.
    I don't really need a choke other than to just keep the car running for the first 30 seconds or so.
    I think I'll use the factory stator stuff first, see if it works. I'm removing pretty much all of the wire looming since I'm doing the EFI delete right and proper. All the wiring will be exposed until I'm happy with how things are, so adding a wire or two for the choke heater won't too much work. I'm not doing a wiring tuck or anything, but I like a clean engine bay.
  13. #533
    Dec 2021
    185
    Yep, when done, wire looms are your best friend!
  14. #534
    41,002
    stator is DC. No AC should be coming out of the alternator unless the diodes are bad.
    all I can say is measure it and see what you get.
  15. #535
    GMN Regular
    Aug 2018
    839
    I could have sworn I read that a while back when I had my 85. I could definitely be mistaken.
  16. #536
    Mar 2010
    Lewisville, TX
    22,746
    I think only the 1G cars with the insta-clear windshield would output full, unrectified, voltage to the windshield, while not charging the battery, to clear the windshield. Those had some special circuit to disconnect the voltage regulator in the process.
    As with any of this info, I might be mistaken.
  17. #537
    Dec 2021
    185
    I think that was a Canadian option?
  18. #538
    Default My '85 MGM, "Maisa"
    Instaclear was available on US cars too. I actually saw two of them in the junkyard earlier this year. One still had the instaclear windshield installed while the other one had an aftermarket non-instaclear.
    If you ever find an instaclear car in the yard be sure to snag the alternator bracket. Those are very useful when doing a 3g alternator swap. They allow fitment of an 8.25 inch alternator instead of being stuck using a 7 inch. Way more clearance with the 8.25 inch.
  19. #539
    GMN Regular
    Aug 2018
    839
    Iím curious now. I did some more research, mostly mustang cfi since thereís more info, and people were saying that stator stud does put out unrectified ac.
  20. #540
    Dec 2021
    185
    Quote Originally Posted by matth825 View Post
    Didn't they come standard with a 100 amp alternator?
