Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 98
Thread: 1994 lincoln town car
  1. #41
    Mar 2010
    Lewisville, TX
    21,616
    But it going away may take some temp cycles to get done.
  2. #42
    PimpDaddy 82EmilioPucci's Avatar
    Jun 2019
    Albia, Iowa
    66
    I did the test agian, i now have a 26, 632, and a 536, got that little scanner in the mail, its sweet!
  3. #43
    39,275
    should be all 3 digit codes there, so not sure what a 26 would be.
    the other two I think are just not pushing stuff during the self test, not actual problems.
  4. #44
    Jun 2019
    Albia, Iowa
    66
    Ok ill do the test agian tomorrow��, the thing the scanner came with said it would scan 1980-1995, is there really a scan port on something that old?
  5. #45
    Jun 2019
    Albia, Iowa
    66
    Ok i did a key on engine off test and got 172, 176, 542 also it did repeat those codes and only showed 10, 111 once, edit the scanner has a c on all but 10 so that must br a scanner thing
  6. #46
    39,275
    Yes. EEC-II (MCU) forward had a self-test. I don't think EEC-1 did but that controlled almost nothing anyway. The older it is, the more limited the code output but by 84 it was getting halfway useful.
    10 is a spacer code between current and stored codes if thats an engine-off scan.
    111 is all-clear, no codes.
    guessing it did 111, 10, then the others? If so key on, engine off is good, space, then you have 3 history codes
    172 is right side lean
    176 is left side lean
    542 is fuel pump circuit fail.
    if those are history, I'd clear them and see if it comes back. If this previously had a fuel pump fuse or fuel pump relay failure it could explain all 3 of those codes. Fuel pump circuit monitors voltage being sent to the pump, not so much that the pump is working. Basically if it loses power you get the fault code. Losing power while driving will make everything go lean and the engine will die.
  7. #47
    Jun 2019
    Albia, Iowa
    66
    I did a running test and got 136, 632, 536, i did start it without those ro hoses on the intake and it stalled, maybe that through the lean code? Also it said cyl 8
  8. #48
    Jun 2019
    Albia, Iowa
    66
    Also the 8 was in code format for example the 136 had a r above it, the 8 had cyl above it
  9. #49
    Jun 2019
    Albia, Iowa
    66
    Nvm the cyl 8 was the reader saying its a 8 cyl i though it was saying like a mis or something
  10. #50
    39,275
    if the intake hose wasn't connected you'll get strange mass air or fuel trim codes. Run it again with all the stuff connected proper like.
  11. #51
    Jun 2019
    Albia, Iowa
    66
    The last test was with eveything hooked back up and the battery had been disconnected the day before, i believe all i have is the 136 now, which im going to but my o2 sensor in first then look for other stuff, also should the pcv valve fit tight, mine seems to fit kind of loose and it look the same as the one i took out, both motorcraft
  12. #52
    GMN Regular
    Mar 2008
    Fredericton, N.B. Canada
    12,529
    Welcome! Take some more pics, next time the weather is good.
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
    Quote Originally Posted by Mainemantom View Post
    You may regret selling it. Think it over.
  13. #53
    Jun 2019
    Albia, Iowa
    66
ID:	54095Click image for larger version.
ID:	54096Click image for larger version.
    Its dirty from it raining off and on, but not bad
  14. #54
    Nov 2012
    Shelby Township, MI
    3,147
    That's not bad at all, very nice!
    Also, Welcome! (better late than never I suppose, lol)
    ~ 1997 GMC Yukon - wannabe winter DD - returning summer 2020, I finally have an engine
    Gone but not forgotten:
  15. #55
    Sep 2008
    Whitestone, NY
    19,154
    Neat blue color.
  16. #56
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,153
    Looks good, tell us the story about it.
  17. #57
    Jun 2019
    Albia, Iowa
    66
    I was told it was a 1 owner till 2017-2018 some where in there and the dude who owned it lived in California, his wife got real sick and wanted to be with the family in iowa, she died the kids moved in kick it out of the garage and made him sell it, the dude before me was going to use it as a hunting car(more or less trash it) but he decided it was to nice and it sat in his garage for and he only drove it in good weather
  18. #58
    GMN Regular
    Mar 2008
    12,529
    Too nice to be used as a hunting car. Great save!
    '94 Crown Victoria
  19. #59
    Jun 2019
    Albia, Iowa
    66
    the o2 sensor fixed my light, thanks for all the help everyone
  20. #60
    Jun 2019
    Albia, Iowa
    66
    Welp, i took a 2 hour round trip in her, made it back with a check air susp light, do you check those codes the same as engine ones? Also i had 3 people in the back, if that has anything to do with it, car sits lower on passenger side rear edit the hole passenger side is sitting lower
