Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: AOD TV Pressure High in Neutral, Transmission Shifts Like the TV Pressure is Low
    88 LTC nfldfordltd's Avatar
    Oct 2005
    Conception Bay South, Newfoundland and Labrador
    889
    Default AOD TV Pressure High in Neutral, Transmission Shifts Like the TV Pressure is Low
    Just got done scanning down through this Transmission thread...can't find anything that resembles the problem I'm having. Here goes:
    I had the transmission overhauled in my 88 Town Car over the winter by my uncle, who was a Ford certified tech and automatic transmission specialist for over 40 years. I removed it from the car and brought it to him, he tore it down and rebuilt it using a combination of new parts, parts from my old transmission and some more from transmissions he had around his shop. I bought a new B&M Tork Master 2000 RPM stall converter and also installed a cooler in front of the radiator for some extra insurance. FWIW, my original AOD case was cracked around the bellhousing (I suspect it was due to the extra-long driveshaft crammed way too tight between the transmission and rear axle, that problem is featured in another thread) so the "new" transmission case is from an 83 T-Bird. All new gaskets and seals internal and external, valve body was done, new OD band, filter. Remainder of parts were best selected from the three different AODs that were combined to make one.
    He calls me and tells me the transmission is ready, so I go pick it up. I bring it home, put a lick of paint on it and put it into the car. It goes in relatively well, no clearance issues with the flex plate and converter or anything else like that. Filled it up with ATF, cycle the gears, seems to be good. Checked TV pressure once warmed up, right on the money at 35 PSI in park with no cable adjustment, simply connected as-is.
    Take it for a test run, the shifting is all kinds of messed up. No 1-2 shift at first, when it finally did upshift into 2nd, then the 2-3 and 3-4 were mushy as shit and piled up.
    Figured it was just bawky from being freshly built. I go home, double check the TV pressure in NEUTRAL this time, bang on at 35 PSI. As the 1-2 shift was so delayed and a bit harsh, I drop the pressure to 30 PSI. Take it for another test run and wouldn't you know, it was behaving like there was zero TV pressure. Early, soft, mushy shifts, no downshifting at all under WOT, starting off in 2nd gear, etc.
    Go home again, check TV pressure in neutral, bang-on 30 PSI. Based on how it was acting at 30 PSI, I shorten the cable to bump the TV pressure to 40 PSI.
    Another road test, another complete failure, albeit a bit better than at 30 PSI. Upshifts are OK, (though not enough 'slip-bump' for my liking) won't go into OD at WOT, but no forced downshifting at any speed from any gear. Still acting like the TV pressure is too low. I verify the TV pressure to be 40 PSI at idle in neutral with the block on the cable between the crimped slug at the end and the square plastic adjustment sleeve. With it removed (when spec is between 0-5 PSI) my transmission is running closer to 30 PSI.
    I get pissed off with it, pull the cable so short as it will go. Lock the white tab in, TV pressure is showing >50 PSI at idle now (no block). Revving makes it go in excess of 80 PSI. I then remove the gauge, road test again. This time the 1-2 shift is perfect, but 2-3 is still too early/soft. 3-4 backout shift happens at just under 35 MPH. Light throttle 3-4 shift happens just under 40 MPH. At 50-60 MPH 3-4-3-4-3-4 shift hunting on a slight grade is brutal. A forced 3-2 downshift will not happen over 15 MPH, making for some pretty embarrassing trips up steep hills, unless I do the AOD shuffle and manually haul it down into low gear. 2-3 shifts are almost immediately after the 1-2 shift at about 20 MPH unless I got the hammer down.
    Has anyone else encountered this type of behaviour from an AOD? My next step is to set up the TV pressure gauge and leave it in place while I drive, just to observe what it does as it's acting like the TV pressure is dropping drastically once the transmission is placed into gear. Not that it will really prove anything, as all the specs for TV pressure are given for when the car is hot idling in neutral...
    I really don't feel like taking that transmission out again...I only just got the rust, dirt and crap out of my eyes from putting it back in Easter weekend. Sick of doing everything right and still not being able to make something work as it should, and having to do stuff over and over and over again...
    Fluid level is good, if anything might be slightly overfull. No leaks. Engine is running very nicely, FWIW it's an HO converted 5.0. Upper intake is stock, EGR spacer is bored out to 58 mm to match the 86 Mustang TB, which has the throttle linkage flipped. Old transmission wasn't like this, if anything it built up too much TV pressure and had delayed/harsh upshifts, no slippage unless it was cold and slightly overfull on fluid, and was noisy in gear. Glad I addressed it when I did, as the case was almost split in two from the crack along the bellhousing. Much longer and it probably would have broken in two and left me stranded on the side of the road like an asshole.
    Summer car-> 1988 Lincoln Town Car, triple blue, 292,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
    Winter vehicle-> 1995 Ford F-250 XLT SuperCab 4x4, 237,xxx+km. AKA "Brutus" 460/E4OD/4.10 axles and 12 MPG. Bought 2019/08/14
    5,632
    Something is wrong internally. Whether that’s a spec of dirt hanging up a shift valve or the governor, a check ball in the wrong place I have no idea. I wouldn’t drive it until you figure it out.
    I have a book on the AOD and I am trying to find out what and how. There is a pressure problem for sure. It seems you have the TV pressure in 1st, but lose it once out of first. It sure what would cause that but I’ll think on it. Line pressure is the other side of the pressure equation. It would be worth a look to see what that is doing. If that is too high, maybe it’s pushing the 2-3 and 3-4 shift valves to short shift. What would cause that, I have no idea.
    Might and to send 88grandmarq a PM.
    1988 Crown Vic Wagon - daily
    Oct 2005
    889
    I did get a tiny piece of brass lost in the TV port when hooking up my gauge once. Maybe that's what's causing my trouble? i would think an obstruction in the TV passage would cause low pressure in all gears...maybe it's still making pressure but blocking something in the valve body or messing with the governor?
    I'm going to try changing my fluid and *hope* the debris comes out when it's drained.
    Wish me luck.
    39,128
    What valve body did he use? There are basically two cases for these, the 80-85 one and the 86+ one. Difference is the early ones have a 3-4 accumulator in the case, late do not. The valve bodies don't interchange between them, but I won't admit to actually knowing what happens if you get that mixed up.
    Sounds like you have the pressure right if its ~35 with the gauge and 0-5 without it. There is also a check in the book, which I don't have in front of me, that says what you should get with the TV pulled all the way out at idle. Sounds like the pressure is not increasing like it ought to be. Since its coming up with cable movement, the TV lever has to be engaged on the regulator valve inside but its possible something is wrong causing it to not increase as much as it should.
    Might have to hook the gauge up in such a way that you can monitor it while driving and see what it does vs what the manual says it should be doing. I suspect you'll find the line pressure is low for whatever reason, and I'll guess its something going on with the valve body. Could even be leakage between the body and the case. Sometimes the gaskets aren't really well made and can leak if not installed exactly so. Torque specs on the valve body are also very critical for things to work correctly. Its some fairly low number of inch-pounds and the torque pattern has to be followed.
    Oct 2005
    889
    I'm not sure which valve body he ended up using, I know he did overhaul the valve body prior to installation. I did get both variations of valve body gasket so he was sure to have one that was right.
    I'm leery about observing the gauge while driving, as there is not TV pressure spec for while driving or in a gear, for that matter. Unless the pressure is dropping to zero, I don't know what's an acceptable TV pressure. That may further cloud my judgement on this whole concern...
    He is very aware of bolt torque spec for the valve body and filter, he lectured me on that when changing filters in the past. 80-85 in. lbs. is the correct torque.
    I have the pan dropped again now and the filter is out, letting it drain, going to remove the valve body tomorrow and see what I can see up yonder.
    The more I think about it, the more I'm inclined towards the little chunk of brass that got into the TV port is causing me grief. I just need to figure out where the TV port goes within the transmission case and attempt to extract it. Hopefully it was big enough that it didn't make it far...
    39,128
    there is stuff in the shop manual about what it should be under what conditions. I know I've looked at it, but the books are in the garage and I'm not at the moment.
    Oct 2005
    889
    My books are for 1986 model year cars. I know 86 was an odd year, but my books also don't say anything about TV pressure during the road test. Says to adjust hot idling in neutral until 35 PSI (+/- 5 PSI) with block, < 5 PSI with block removed. Do not drive if PSI is lower than spec, road test to confirm.
    Which is what I've done, but like I said earlier, my road tests are resulting in the car acting like there is next to zero TV pressure.
    I still haven't dropped the valve body to investigate the insides further or to try to find the chunk of brass that went into the TV port, or done a line pressure test. If I can find and remove the foreign debris, I will then do the line pressure test and see what that's saying.
    Always something with this fu(king car, honest to God...
    39,128
    bah, 91 manual says "control pressure specs can be found in the special specifications booklet" which I do not have.
    looking over the trouble chart, all of it says low control pressure, sticky valve body, or governor problems.
    Gov check is to accel to 25 mph then completely back off the throttle. If it doesn't kick to third, the gov isn't working properly.
    84 manual has nothing trans related, my 85 powertrain manual just tells how to set the TV linkage and rebuild it. No troubleshooting or diag stuff. I didn't look at the 86 manual but its likely the same one you have.
    Oct 2005
    889
    Thanks for the info.
    I don't think I will have any trouble making it pass the governor test like that, as it upshifts too readily already. It's the downshifting (or lack thereof) that's concerning me.
    Wasn't there a variation of box panther that had a '2nd gear lockout' to prevent engine overspeed? I'm thinking it may have been a police interceptor feature? Or am I totally out to lunch on that one?
    I may get another governor and try it to see if it makes any difference. I did drop the valve body the other night, everything looked fine. I did get the chunk of brass out of an oil galley, and for kicks I pulled the 2-3 accumulator to have a look, as 2-3 and 3-2 shifts seem to be the worst affected. Everything looked great.
    My transmission does have a 3-4 accumulator piston in the front left corner of the case, so I assume it has been built to an earlier model standard. Builder says he's stumped, figures a bottle of friction modifier MAY help.
    It's never good when the tranny guy says to put additives into the transmission lol
    39,128
    police cars had "2" as the lowest gear rather than "L". Different valve body.
    may be worth getting hold of the special spec book and checking what exactly the line pressures are under what conditions. The trouble chart has stuff like if its low in this position but not that position, go here, look at that, etc. Also maybe post over at clickclickracing. They're AOD guys and might have more insight. I've never had my hands in one beyond changing a valve body.
    Oct 2005
    889
    First casualty today from running it with too much TV pressure...output shaft housing seal blew out of the extension housing, slid back on the drive shaft yoke. Coated the underbelly of the car with ATF and made a fine cloud of smoke and droplets on my way home today.
    I took the driveshaft out and put the seal back in. Before I reinstalled it, I put a thick coating of loctite on the mating surfaces of the seal and the transmission extension housing in an effort to help it stay in place.
    I'm going to need a valvebody I think. Governor tests fine (drive it to 25 mph, back out the throttle, goes into 3rd). Only other thing it could be far as I can see.
    39,128
    That seal should not actually be under any pressure. There is a vent in the case that is supposed to relieve any pressure from heat expansion though, might want to check that. Its a little button looking thing on the main case, right where the tailshaft bolts up.
    is the bushing in the tailshaft any good? If thats really sloppy the drive shaft can move around and it might be enough to grab and yank the seal out. Rusty driveshaft yoke might also do it.
    here's an off the wall thought, is it the proper dipstick and tube? I don't honestly know if there are multiple choices for the AOD besides the obviously goofy looking van one but I'm wondering if the fluid level is not actually correct because the dipstick lies. How much fluid went in on initial install? Should be pretty darn close to 3 gallons / ~11 liters for a completely dry trans and converter. If its more than 3.5 gallons I'd be concerned about the dipstick accuracy.
    Oct 2005
    889
    I don't remember seeing any vents on the main case when I put it into the car, it blows the dipstick out during sustained highway driving. Is it possible only later model AODs had the vent?
    Very good point about the tailshaft bushing. I noted the tailshaft moved laterally significantly when the driveshaft was out to replace the seal. I also noticed significant driveline vibration at highway speeds as well, supports the tailshaft bushing being pooched theory.
    Upon installation, the dry transmission took about 10-11 liters to fill. 4 liters, start and let it set settle. Then 4 more, let it run and top off with 2-3 more liters.
    The dipstick is the one from the original transmission that came out of the car in 2008-2009, when that one had to be replaced. I kept it and replaced the O-ring in it over the winter while my transmission was sent off to be overhauled, so he didn't mix it up with a truck dipstick or anything like that.
    Oct 2005
    889
    "I don't remember seeing any vents on the main case when I put it into the car, it blows the dipstick out during sustained highway driving. Is it possible only later model AODs had the vent?"
    EDIT: I looked a a couple pictures I took of the transmission prior to installation, it does have a vent on the top back by the extension housing.
    Jul 2014
    Canada
    1,998
    I'm having balance issues after doing the aluminum driveshaft swap with a crap bushing. I read something about the aluminum driveshaft having a dot that is supposed to line up with a paint mark on the tailshaft. My driveshaft had blue and yellow dots, though I'm pretty sure the yellow is supposed to be used. I had seen the paint on the end of the tailshaft but had not been aware of its significance. I read about another type of car (possibly a Mustang) that is supposed to have a paint mark on the diff flange or wherever for the same purpose. I'm going to try repositioning the driveshaft before having the bushing dealt with (hopefully at a shop that has the tools to replace the bushing without removing the housing). I had trouble recently finding the source I had seen previously, but it must be out there somewhere. Not sure if that will be useful for you, but it might be something to consider.
    Oct 2005
    889
    Mine is so Frankensteined now that if the paint marks WERE visible, they have lost their significance anyway.
    -88 Town Car
    -HO converted 5.0
    -1983 AOD made up from three different transmissions and a couple new parts, including 2000 RPM stall B&M TorkMaster convertor
    -Driveshaft 'presumed' to be from a box Ford or Mercury (2 3/8" shorter than the driveshaft that came out of the Lincoln, believed to be about 1" too long and probably an incorrect part to begin with)
    -Only thing original and untouched in the driveline is the rear axle, that's a Y-code
    FWIW, my output shaft had at an estimated 1/4" of lateral play with the driveshaft and extension housing seal removed. Definitely bad bushing, which explains the vibration.
    Good luck sorting your balance issues.
    39,128
    If the dipstick is blowing out you've definitely got case breathing problems. Make sure that vent isn't clogged or smashed or whatever.
    reason I was wondering about dipstick length, if the trans is over-full it will froth the fluid and act generally shitty. Sounds like the amount of fluid I'd expect though.
    Jul 2014
    Canada
    1,998
    Quote Originally Posted by nfldfordltd View Post
    ... FWIW, my output shaft had at an estimated 1/4" of lateral play with the driveshaft and extension housing seal removed. Definitely bad bushing, which explains the vibration. ...
    The tailshaft on mine had lots of play, but that might be normal. When I looked into it, I saw something about the tailshaft being so long that it exaggerates the play in the internal bushing or whatever.
    I saw a fair bit of stuff on YouTube about dealing with balance issues, but you need a hoist (or bravery with jack stands). I remember one where they used a cup of water (probably in a cup holder) to see how much vibration they were getting without having to do a test drive. If the tailshaft housing bushing doesn't cure it, you might have some luck with something like that.
    39,128
    If its a Ford driveshaft, that'll be shorter than what a Lincoln wants and you won't get as much yoke engagement. 'course I have no idea what driveshaft you had in there before that was too long. I wasn't even aware one existed that was longer than the Towncar piece.
    Is it possible that the new built AOD is longer than the original, so the original driveshaft is bottoming against the rear seal?
    It really sounds like there's a problem with the combination of parts. Since there's so much used stuff in there from 3 different transmissions from different cars and different years, it's just possible that even if the parts are right, some of them aren't playing well together.
    I certainly don't doubt your uncle's ability, I'm just saying that when there's a stack of 30-year-old-parts to choose the least worst of, it's easy to miss a chip or crack that will make everything work differently than expected--with this sort of result. It might be wise to pull it, bring it back, and ask him to double-check the parts inside.
