Is there any other way to install a clutch pedal, without welding it to the current bracket? Couldn't I just put in a mustang or f150 assembly and just drill in new mounting points?
Manual swap pedal assembly
Check out YouTube 50tussin I believe is the user name. Me.Blue on this forum. He adapted a mustang pedal assembly with some bits of his Lincoln pedal assembly to his car. Not much details on the video but he did do it.
I’ve built a panther pedal assembly with clutch pedal and it looks oem. My father had no idea it was something I built and he has worked for Ford since the 80’s. It is not too hard to do.~David~
Originally posted by 87gtVIC View PostCheck out YouTube 50tussin I believe is the user name. Me.Blue on this forum. He adapted a mustang pedal assembly with some bits of his Lincoln pedal assembly to his car. Not much details on the video but he did do it.
no small amount of it has to do with how you beat on it. GoodSamaritan used to run a 4 cyl T5 in a station wagon. It was behind a lopo but it had oversize tires and a lift kit.86 Lincoln Town Car (Galactica).
Originally posted by LongDongJohnson View PostI just checked out his channel, and I got to say he's a pretty cool host. Plus I was a bit a t5 can handle the weight of that lincoln, Ive been underestimating those gearboxes.
It will last forever if used normally. Power shifting will kill it I am sure.~David~
Originally posted by gadget73 View Postno small amount of it has to do with how you beat on it. GoodSamaritan used to run a 4 cyl T5 in a station wagon. It was behind a lopo but it had oversize tires and a lift kit.
Originally posted by 87gtVIC View PostHe is a really cool dude from the videos. Dont know if the t5 will handle the lincoln as it has not been down the track yet. He LOVES the drag strip. Lucky for him he knows how to rebuild them...and has had to rebuild them from running them in his mustangs.
The upgraded bearing retainers.
With these cars it seems the rear ends can explode. A rear end girdle is recommended to prevent the main caps from pull out.~David~
What year car are you looking to put this into? If 89 and lower I can build you one if your provide everything. ....Mustang pedal assembly, panther pedal assembly and info if you want the cruise deactivate switch as well as the clutch sense switch as well as clutch safety switch. It is all custom work but I have done it and know what to do.
My build progress of the assembly.
http://www.grandmarq.net/vb/showthre...l=1#post810949
After getting this one installed I found out things I would like to to differently as well. So the next one that comes out would be even better.
You let me know.~David~
I used my stock drive shaft. Fit perfectly right into the manual trans.~David~
