Odd question- will 96-97 rear brakes bolt up to the 95 and lower rear brake backing plates? (i split the years because there was a mid-year switch in 95 i ran into) Theres better pad selection on the newer brake setup, so it would be ideal to go with them. Not sure if anyone has tried or can confirm?
Rear brakes
Rear brakes
+2003 Acura CL Type S 6-speedTags: None
I think the backer plates are the same, just the caliper changed. Pads go with the caliper.86 Lincoln Town Car (Galactica).
I tried to do a part number search, there’a a PN with the F5 aka 95 designation, one site says it’s usable on an earlier model Lincoln... I can’t find a part number for the earlier backing plate. I’ll keep looking, but I feel like finding that PN is the key for definitive confirmation-Phil
a master parts manual for 90s stuff would confirm. It would indicate if one p/n superseded the other. Mine ends at 198986 Lincoln Town Car (Galactica).
