My last question and answers got lost
    About a month and a half ago i asked a question and you guys came back with answers, It was under the box tech but now I cant find it anymore. Any ideas of what happened? Thanks Gary
    Was it the question about no heat?
    That's the newest post I found from you using the search function. www.grandmarq.net/vb/showthread.php?56692-no-heat
    But that was November.
      No not about heat. It was about hotter spark plug for one that is fouling.
        Interesting that I see Results 1 to 11 of 12 but there is no second page to view.
        Makes me wonder if there is a post that has been hidden or if this is just the result of the search function sucking. Someone with admin access would be able to see the post of it has been hidden. As a non admin user, that's as much as I will be able to find out.
          nope, nothing to find
          so whats the question? If its about running hotter plugs to try and deal with oil fouling, the short answer is no. The long answer is to figure out what is causing the problem and fix that. Without context, guessing valve seals or something with the PCV system. Missing screen, that kind of thing. I've seen some revised routing to the PCV hose that is supposed to deal with fouling on the rear plugs but I don't remember where or any further details.
            +1 didn't find anything. Sure this was the forum you asked on?
