Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
Thread: Surge and Rough Idle
  1. #21
    Dec 2019
    Fort Irwin, CA
    20
    Turns out the canister purge solenoid was attached to the line. It was so totally encrusted in dirt, though, that I didn't notice it. Also surprising was my discovery that the charcoal canister lives under the battery by the cornering lamp. I had thought for some reason that it would be back by the gas tank. They didn't make it easy to get a good look at that thing, but it shouldn't be too hard to reattach the vacuum line.
    I took my first step toward working on the actual engine yesterday by pulling apart the throttle body and upper intake. I didn't expect everything behind the throttle plate to be so thoroughly coated in carbon. It looks like the buildup on the intake passage is thicker and 'wetter' than the exhaust return beneath it. Is this normal and should I try to clean what I can in there? It looks like it's impossible to physically reach most of the intake, but maybe a little cleaning is better than nothing.
    The gasket to the lower intake has '93334' written on it, which makes me think it's a Fel-Pro and someone's been here before.
    Attached Thumbnails Attached Thumbnails 20200505_183428.jpg   20200505_183921.jpg   20200505_190458.jpg
  2. #22
    39,131
    They get nasty. Small center hole is exhaust gas flow for EGR, which ends up pulling through the 8 runners when the EGR valve opens. It also gets some oil through the PCV. I wouldn't go crazy with it but if you can dump some degreaser in there to soak for a while and give it a scrub it won't hurt. Spray 9 works pretty good and won't destroy aluminum. The others also work but just watch leaving anything with sodium hydroxide (lye) as an active ingredient in conctact with aluminum for too long. It does bad things.
    if the valve covers are not leaking oil, thats probably why someone has been here before. The cork gaskets these came with 30+ years ago just don't survive forever. The lower intake gasket in the rear is also a common oil vomit point.
  3. #23
    Dec 2019
    Fort Irwin, CA
    20
    It appears, after a little cleaning around the edges, that the valve cover gaskets have been replaced. I was going to pull the covers just to see how things look inside, but now I'm thinking it might be better to just leave them be.
    I'm having a hell of a time disconnecting the fuel lines. I think I understand how the disconnects work in principle, but in practice they aren't budging. I'm also not sure where I should be sticking the disconnect tool. The line over by the thermostat appears to have room to stick a disconnect tool over the narrowest part of the line, pulling it apart from the larger, transmission-shaped thing. But on the other line the geometry differs and the line flares into the largest part of the "transmission" apparatus. The only place I can seem to fit a disconnect tool is on the back side of the flared part, as shown in the picture attached. But it looks like there's an o-ring in there.
    So all in all I'm a little confused. But I'm hoping to get the fuel rail disconnected and off so I can move on to the part where the intake bolts snap off on me.
    Attached Thumbnails Attached Thumbnails 20200521_153938.jpg   20200521_154020.jpg
  4. #24
    Mar 2006
    Bedford, VA
    5,633
    You have it on right. Push it up in there as far as it will go to release the clip. Then you have to pull, hard, if they haven’t been messed with in a while. Sometimes helps to have a helper pull the other side of the line while you hold the tool in and pull the opposing side.
    1988 Crown Vic Wagon - daily
  5. #25
    Dec 2019
    Fort Irwin, CA
    20
    I seriously underestimated how hard I had to pull to get get it off, but one down, one to go.
    The last big thing I'm uncertain about is pulling the distributor. If I understand correctly, the cap should only go on one way, so that shouldn't be a problem. Then the rotor and distributor both can move and are important to mark their position. The rotor should be fixed in place by the gear, so I don't need to worry too much about getting that right? But the distributor will rotate in place as soon as I loosen the bolt? What I don't have a good feel for is how fussy that rotation is to the ignition timing. Does one degree of rotation on the distributor equal one degree on the timing mark? If so then I guess I have to be basically dead on with the position to retain the old timing.
  6. #26
    Sep 2014
    Warren, MI
    5,854
    Oh yeah, you better believe you ought to record the position of the rotor before you pull the dizzy out. I made that mistake with Ashley's old '89 TC. I ended up stabbing the thing back in a tooth retarded. Fired right up but had zero balls, couldn't even get it out of the grass.. Lots of steam from the exhaust too, I think it was the tig man himself who helped us out of that bind. I was mere millimeters away from calling a tow truck..
  7. #27
    Mar 2006
    Bedford, VA
    5,633
    The rotor will rotate too when you pull it out. Mark the tip of the rotor to the distributor cap “bottom part”. Mark the base of the distributor at the engine block. As long as both line up when put it back in, you are good.
  8. #28
    Sep 2008
    Whitestone, NY
    19,104
    Dont rotate engine while dizzy is removed.
  9. #29
    39,131
    I usually mark the rotor position twice, once with the distributor installed, and again when it comes out. Makes it slightly easier to re-align when it goes back in. Make sure the gasket set comes with the distributor O-ring too. Lube that when you install it otherwise it will be annoying.
    +1 on not rotating the engine.
    Its not all that hard to re-orient those parts if something does happen but no point in doing it if you don't have to.
  10. #30
    Dec 2019
    Fort Irwin, CA
    20
    I made great strides toward unearthing the lower intake today. Distributor was marked and removed. The new gasket set did come with a replacement o-ring, but the distributor itself is only 7 months old (after the ignition pickup died just out of Eureka on our honeymoon.) Are these o-rings single use or can they go a few years between replacement?
    The fuel rail made it off following the disconnect of the second line. I didn't think it'd ever come apart, but after plenty of coaxing and pulling it finally humored me and came loose. So far I've spilled a little gas and coolant, which probably makes me an eco-fugitive in the State of California.
    I removed the stud holding the upper alternator bracket to the intake and found the threads coated in a bit of oil. Not sure whether this means the head to intake gasket failed and I've been burning oil in the #5 cylinder (and maybe elsewhere), or oil has just been pouring out the front and rear valley seals and a little splashed up from below.
    Tomorrow is the moment of truth. I hit all the bolts with a little WD40 overnight to hopefully loosen up anything that might need it. If I can get everything unbolted without issue then I think I'll be okay. I have FelPro replacement gaskets, including the rubber pieces that span between the heads. Are these worth using over a thick bead of RTV? And what's the best practice on sealant around the coolant passages? Is it a little extra insurance or am I potentially compromising the gasket's effectiveness by adding more material around these points?
  11. #31
    39,131
    should be fine on the O-ring then. If its soft it will seal. After decades they get hard as a rock and will shatter if you poke at them. Same with the PCV valve grommet. I've actually stood on them without it deforming before, and I'm something of a fat ass.
    oil on the alternator bolt probably wicked there from a leaky valve cover gasket. Those go into a blind hole in the head. If the valve cover gaskets aren't the rubber ones, I'd change them while you have it open. Cork just don't last forever. Otherwise no need to open it. If the engine is nasty inside, you'll see it from inside the lifter galley when the lower intake comes off.
    Make sure the gasket surfaces are clean and flat. If there is pitting, a very very light wipe of RTV around the coolant passages will work. You want a dab in the 4 corners where the side gaskets meet the end wall gaskets. I use long bolts with the heads cut off as guide pins to hold the gaskets and align the intake on assembly. Pretty sure its a 5/16" bolt. If you get four that are 4" long and chop the heads off that'll do it.
    A few random suggestions. If you're removing the injectors from the lower intake, replace the O rings on them. If the caps are cracked you can get those too. Sometimes its sold as an "injector rebuild kit", but it will come with the cap and a pair of O rings. Might also not be a terrible idea to replace the fuel rail O rings either. You want the Viton seals. Not sure if the parts stores have them but its the same O rings Mustangs use, and I've bought them from Mustang places before. Usually they recycle OK but I have torn them in the past. I'd also give the upper and lower intake a good cleaning inside and out. The goo and sludge in there won't be doing you any performance favors. Don't get crazy trying to get it pristine but if you've got a big tote that you can mix up some degreaser in to let it soak, may as well. The Duplicolor Cast Coat Alumimum does a nice job of making things look like fresh raw cast aluminum too if you have any desire to pretty it up. The upper intake was painted a grey color but the lower was just raw aluminum.
  12. #32
    Mar 2006
    Bedford, VA
    5,633
    If you have the awesome blue silicone intake end gaskets, use them.
    Distributor o-ring can be reused since itís newer.
    I usually put a very thin layer of rtv around the coolant passages on the intake and the heads.
  13. #33
    Dec 2019
    Fort Irwin, CA
    20
    I'll order some o-rings for the injectors and fuel rail. Might as well do everything while I'm in here. I did the PCV valve, screen, and grommet in January, which was a lot of fun with the intake in place. The grommet never fit very well though, so I'll put a little heat shrink tubing around it before reinstalling.
    Thankfully all 12 intake bolts came out without a hitch. Of the eight middle bolts, six were immaculate, while the two around the driver's side EGR passage were a little corroded. I assume the gasket failed and baked them in exhaust. The four corner bolts were all covered in sludge, which had me a little worried about what I'd find inside. But the lifter valley looks pretty good in my novice opinion. Most buildup looks like it's on the underside of the intake, and maybe on the pushrods - I don't know if that's a problem or not. A little coolant spilled into the valley as I removed the intake, but I'm hoping the engine will survive until I change the oil once it's all back together.
    The gaskets have definitely seen better days. I don't know if they're the originals, but they definitely look old. Whoever installed them seems to have put RTV around the coolant and EGR passages. The gaskets also cover up these four depressions on the heads between the middle and outer cylinders which seem to be designed to pool oil. I don't know how that much oil is getting in there or whether it's an intended feature, but I was a little surprised to find it.
    As for cleaning things up, I'm actually working on polishing the upper intake and EGR spacer. Not sure if I'll do the throttle body since the geometry is pretty tight. And the lower intake has some tricky spots too. But when they're done I was thinking of just putting a clear coat on to keep the aluminum from oxidizing. I don't know whether I need a heat tolerant paint or just whatever, as I don't think the intake should get too hot.
    Attached Thumbnails Attached Thumbnails 20200523_145045.jpg   20200523_145735.jpg   20200523_151854.jpg   20200518_174904.jpg
  14. #34
    39,131
    looks like this one had better oil change care than coolant system. Engine looks great, not so much on those coolant passages. I've been in engines that had big oil cookies that had to be broken up and vacuumed out before.
    standard paint should be OK. Just have to do something or it will turn into an oxidized mess again. The ones on my car are actually done in cast coat iron, makes for a nice dark grey. I did the manifold and valve cover on the diesel and actually had someone ask me where I got an NOS intake.
