Results 1 to 3 of 3
Thread: Bilstein rear shocks
  1. #1
    Jan 2008
    New Jersey
    2,908
    Default Bilstein rear shocks
    Those of you who have installed Bilstein rear shocks- how in the world did you tighten the lock nut they included for the top of the shock. I see theres a slot for an allen wrench, but i cant get one in that tiny space along with a regular wrench. Did you cut the upper trunk pan for access?
    -Phil
    +1982 Ford LTD-S Police Car. 351w, GT40 Heads, Edelbrock 1906 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. Speedway Springs+Bilstein Shocks, Intermediate Brakes, Baumann Shift kit.
    +1975 Maverick- Fuel injected 302, Trickflow 170 heads, XE270 cam, explorer intakes, 24# injectors, custom tune. T5 transmission, 3.55 Yukon Trac-Lok rear.
  2. #2
    39,260
    does it include a metal shroud attached to the upper shaft? Might be able to hold that.
  3. #3
    Jan 2008
    New Jersey
    2,908
    No itís like a plastic/rubber one that is separable
