Parking light screw size
    Does anyone know the size of the screw that holds the side marker housing on a whale?
    If you can't find it I can go pull one out of my 03 and check it.
      I would appreciate it. I remember it being a coarse thread maybe #8 or so on my 98 p71. They’re cheap enough to buy a few of and try out if need be.
        Ok, just pulled one. It's 1" long from the backside of the head to the end, 1/8" wide, has 16 coarse threads on it. And it's stainless. Not sure what screw size that equates to but there you go.
          Thanks man, I ended up buying a pack of #8 sheet metal screws to try out. I don’t have the car right now but when I do I’ll try them. I’m sure its the same size. Thanks again!
