Results 1 to 16 of 16
Thread: Lmr 130 amp kit
  1. #1
    Default Lmr 130 amp kit
    I know its not the cheapest option, but late model restoration makes an alternator conversion kit. It comes with a large guage wire n stuff. Its shows up as a kit for the 88-93 foxbody. Any thaughts on if this will work on a panther?
  2. #2
    Jan 2008
    New Jersey
    2,893
    I can't imagine it not working (I assume its a 3G) is this it: https://lmr.com/item/SVE-17046K2/Mus...aAjvUEALw_wcB?
    The wires might not be the right length though- hard to tell. That being said you could make this kit for $100 or more less
    -Phil
    +1982 Ford LTD-S Police Car. 351w, GT40 Heads, Edelbrock 1906 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. Speedway Springs+Bilstein Shocks, Intermediate Brakes, Baumann Shift kit.
    +1975 Maverick- Fuel injected 302, Trickflow 170 heads, XE270 cam, explorer intakes, 24# injectors, custom tune. T5 transmission, 3.55 Yukon Trac-Lok rear.
  3. #3
    Sweet. So my 88 has an aftermarket security system thing with remote trunk and remote start. The remote start works every time on the second crank. Im hoping a 3g and high torque mini starter Will do the trick.
  4. #4
    That 82 ltd is awesome. What cam did you go with? That mavrick must be fun to drive.
  5. #5
    Sep 2008
    Whitestone, NY
    19,099
    Like was mentioned it can work but certain components of the kit will likely not work for you....like the wire length.
    I purchased a similar kit from LMR for my fathers 85 Mustang GT. I was happy with what money was spent.
  6. #6
    Sep 2014
    Warren, MI
    5,846
    For my '88 TC, I just used the alternator wiring from a '93 or so Continental, complete with it's fusible links. It went from the stud on the starter solenoid up along the core support, down along the driver's side frame rail and up to the 3G alternator no problem. If I did it again, I'd probably splice two of those Conti harnesses together so I can make run up to the alternator like the factory harness does, from the washer/coolant overflow bottle area. I also left the 2G charge wires in place, zero issues and back then, I drove the shit out of that car. Garage queen now.
  7. #7
    Jan 2007
    Westmont, New Jersey
    10,368
    I have used the power wire kit before. It is plenty of wire to reach on a box. The battery and alternator connections are the same distance apart between the fox and the panther. They don't seem to just list a 2g-3g kit anymore, which would cover everything you'd need for the swap including wiring and the pigtails. Realistically you can use a 98 Taurus 3.0 ohv 130 amp alternator and get the same results. You will need to slightly enlarge the lower mounting hole in the alternator to allow your bolt to fit through, and the upper mount you will use a different bolt, with a nut and washer. You may have to use a slightly longer bolt to fit the pulley. You will need a charge cable. I would strongly recommend this, as it will easily support the extra output that the alternator can make. You can utilize the stock charge wires too if you so choose. Just cut the ends off and add the ring terminals and you'll be good to go. The 2g regulator plug is the same as the 3g. You will just need the stator pigtail.
  8. #8
    Jan 2007
    10,368
    https://lmr.com/item/SVE-17046K2/Mus...rade-87-93-50L nvm I found it. That will all work. Or you can piece it together.
  9. #9
    39,122
    I keep meaning to tap the top hole in the alternator so I don't need to use the nut and bolt. I converted the alternator like 15 years ago, so maybe by 2040 I'll have gotten around to doing it. My luck as soon as I tap the thing it will fail.
  10. #10
    Sep 2008
    Whitestone, NY
    19,099
    It is a nice touch doing it that way. I did it on my initial install and dont regret it. Makes getting the proper tension a tad easier.
  11. #11
    The kit came in today. Looks great in black. The alternator itself looks huge. Have you guys tried the high torque mini starters? Im also thinking about a reserve battery in the trunk like modern cop cars..
  12. #12
    Sep 2008
    Whitestone, NY
    19,099
    Cool. you got the black one.
    I have the mini starter on mine from LMR.
  13. #13
    39,122
    whenever mine barfs I'll swap to the small starter.
  14. #14
    Mar 2010
    Lewisville, TX
    21,544
    I put a ministarter on the 88 MGM I had when that starter died. Just a parts store special for a 91.
  15. #15
    39,122
    The chunker starter on it was put on like 2 days before Scottfest 2005.
  16. #16
    Jan 2007
    10,368
    I like the sound of the older starter. Plus they're cheaper.
