Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Lmr 130 amp kit
    Default Lmr 130 amp kit
    I know its not the cheapest option, but late model restoration makes an alternator conversion kit. It comes with a large guage wire n stuff. Its shows up as a kit for the 88-93 foxbody. Any thaughts on if this will work on a panther?
    Jan 2008
    New Jersey
    3,108
    I can't imagine it not working (I assume its a 3G) is this it: https://lmr.com/item/SVE-17046K2/Mus...aAjvUEALw_wcB?
    The wires might not be the right length though- hard to tell. That being said you could make this kit for $100 or more less
    Sweet. So my 88 has an aftermarket security system thing with remote trunk and remote start. The remote start works every time on the second crank. Im hoping a 3g and high torque mini starter Will do the trick.
    That 82 ltd is awesome. What cam did you go with? That mavrick must be fun to drive.
    19,970
    Like was mentioned it can work but certain components of the kit will likely not work for you....like the wire length.
    I purchased a similar kit from LMR for my fathers 85 Mustang GT. I was happy with what money was spent.
    Sep 2014
    Warren, MI
    6,283
    For my '88 TC, I just used the alternator wiring from a '93 or so Continental, complete with it's fusible links. It went from the stud on the starter solenoid up along the core support, down along the driver's side frame rail and up to the 3G alternator no problem. If I did it again, I'd probably splice two of those Conti harnesses together so I can make run up to the alternator like the factory harness does, from the washer/coolant overflow bottle area. I also left the 2G charge wires in place, zero issues and back then, I drove the shit out of that car. Garage queen now.
    Jan 2007
    Westmont, New Jersey
    10,390
    I have used the power wire kit before. It is plenty of wire to reach on a box. The battery and alternator connections are the same distance apart between the fox and the panther. They don't seem to just list a 2g-3g kit anymore, which would cover everything you'd need for the swap including wiring and the pigtails. Realistically you can use a 98 Taurus 3.0 ohv 130 amp alternator and get the same results. You will need to slightly enlarge the lower mounting hole in the alternator to allow your bolt to fit through, and the upper mount you will use a different bolt, with a nut and washer. You may have to use a slightly longer bolt to fit the pulley. You will need a charge cable. I would strongly recommend this, as it will easily support the extra output that the alternator can make. You can utilize the stock charge wires too if you so choose. Just cut the ends off and add the ring terminals and you'll be good to go. The 2g regulator plug is the same as the 3g. You will just need the stator pigtail.
    Jan 2007
    10,390
    https://lmr.com/item/SVE-17046K2/Mus...rade-87-93-50L nvm I found it. That will all work. Or you can piece it together.
    40,138
    I keep meaning to tap the top hole in the alternator so I don't need to use the nut and bolt. I converted the alternator like 15 years ago, so maybe by 2040 I'll have gotten around to doing it. My luck as soon as I tap the thing it will fail.
    19,970
    It is a nice touch doing it that way. I did it on my initial install and dont regret it. Makes getting the proper tension a tad easier.
    The kit came in today. Looks great in black. The alternator itself looks huge. Have you guys tried the high torque mini starters? Im also thinking about a reserve battery in the trunk like modern cop cars..
    19,970
    Cool. you got the black one.
    I have the mini starter on mine from LMR.
    40,138
    whenever mine barfs I'll swap to the small starter.
    22,140
    I put a ministarter on the 88 MGM I had when that starter died. Just a parts store special for a 91.
    40,138
    The chunker starter on it was put on like 2 days before Scottfest 2005.
    Jan 2007
    10,390
    I like the sound of the older starter. Plus they're cheaper.
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,719
    I want to order this kit for the 89 TC. The question I have is this: Is the alternator bracket for a 302 Mustang offered in this kit compatible with the TC bracket ? Has anyone used this ? I want a total plug and play mod. ThanksClick image for larger version.
Name:	sve-mustang-130-amp-alternator-bracket-full-upgrade-kit-86-93-5-0-5-8_8e155670.jpg
    Nov 2014
    Evans, GA
    1,754
    You shouldn't need to swap the bracket, plus the Mustang has it on the wrong side of the engine. The 3G and 6G alternators will go right into our brackets with essentially no fuss. I've heard some folks have had to grind their brackets a little to get enough adjustment, but I've put a 3G in a '85 LTD and a '89 Colony Park with no grinding, and I've had a 3G and recently fitted a 6G in my '87.
    That kit will definitely provide everything else you need though. If you really wanted to avoid cutting on your factory harness very much, you can even re-use your existing voltage regulator plug. Just gotta cut the white stator wire and splice on the new single plug connector from that kit to it.
    -1997 Grand Marquis LS (222K Miles) - The Daily Workhorse & March 2015 + January 2019 POTM Winner
    19,970
    Skip the bracket wont do you any good.
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,719
    Good advise, thanks. Will order hopefully today. I will have my mechanic install it. At $70 an hour I don't want him dinking around trying to get stuff to fit.
