So I知 trying to swap from the base fleet radio to the upper level radio with a cd player in my 09 P71. I have the 16 pin radio harness and I知 making a harness to put in the 24 pin harness following the pinout on
http://www.idmsvcs.com/2vmod/radio/index.html
The issue I知 running into is that some of the pins don稚 seem to be in the right spot and when I plug in the new radio if I press the on button the clock will display for a few seconds then go blank. Can anyone confirm the wiring schematic in that link is correct? It could be the head unit but I want to rule out my wiring job first.
