converted to Explorer rear disc brakes - are brakes dragging? Pedal could be better
    Hi Everyone,
    I recently upgraded my 8.8 rear in 84 wagon to 31 spline axles, 9" housing ends etc and Explorer rear disc brakes. I think these brakes have a 1 7/8" piston. Looking at the specs gadget posted in a sticky, front stock calipers have 2 7/8" piston and the master cylinder is 1". seems like this combo should be good but my pedal is softer than before and I'm concerned that the stock master cylinder may have a residual pressure valve thus dragging the rear brakes....
    Any thoughts? I'm thinking a disc/disc MC would be better but would a smaller MC bore (say 15/16 or 7/8) give me a firmer pedal?
    Thanks!
    1984 Mercury Colony Park Wagon - 393 Dart block LS 91mm turbo with 4L80E and 9" 6.24@115 in the 1/8 mile (9's in the 1/4), 4650lbs w driver, AC, Drag n Drive rig 1300hp
    1988 Lincoln Town Car - stock for now
    More than likely you have a residual pressure valve. Also, and perhaps in the same device, a proportioning device. I can say in my old 89 wagon I opened up the device, which screwed into the master, removed the pressure holding component and reamed out the valve to reduce the proportioning effect. Then added an adjustable proportioning valve. I wound up after much testing leaving the adjustable valve completely open for best braking balance. The variable is i don't remember what size drill bit I used to ream open the proportioning valve so you may need to use the adjustable valve depending on how much you open the stock valve.
    84 may be have a different setup to do the same two things.
      yes on the residual valve, and the proportioning won't be quite right either. You want a master and a prop valve from a 90s or later car with disc/disc. If you use the 90s booster that should also help somewhat with pedal feel. More assist possible, but its a better design. Smaller diameter too, which is the magic trick for fitting an extra pedal in one of these.
      Also be absolutely sure you have all the air out. Not sure where the bleeders sit on Explorer brakes when mounted to your rear end but you may have to dismount them, shove a board in between the pads and rotate them around to get that last little bubble out.
        Interesting. The guy I use for custom work sometimes suggested a 1 1/8" mark V master cylinder for more fluid push and stiffer pedal, which I would like. If you all think the 90s mc would be better I can go with that instead
          is the residual valve in line somewhere or it is housed in the prop valve that is mounted on the frame below the master cylinder?
            OK, I think the residual valve must be in the combination/prop valve that is on the frame rail. It's strange - has both brake lines from the master going in and 3 lines going out: one to each from caliper and a single line for the rear brakes that gets split to each side at the rear axle.
            I have a test n tune scheduled for this weekend about 90 miles away from home - is the brake drag from leaving the residual valve in the brake system bad enough to cause any damage to the rear disc brakes or will it be a problem for some drag racing? I suspect so, but I don't really know how big of deal this is....Thanks!
              I think all the valving is in that block on the frame. The late 90s cars with dual piston front calipers and rear disc still used the same 1" piston as the 80s cars with rear drum and small front disc. The pedal on my 86 with all late 90s brake parts is not spongy and doesn't have excessive travel at all.
              The 2 in, 3 out was just because it needs to get to 2 front brakes somehow. When the block goes away you can just install a tee to get that done.
              Probably not a real problem for racing but it will wear the pads a bit more quickly. Take it for a couple mile test drive. If the rear brakes aren't noticeably hot, don't worry about it. Just drive carefully if the brake pedal feels funky.
                Yeah, those brakes are definitely dragging, jacked up the rear end and it's tough to spin the rear tires in neutral and I can hear the pads scraping the rotors.
                It appears that the fittings in the combination valve might be different sizes? same size lines I think. Definitely have 2 different size fittings in the master cylinder. Does anyone know what those might be? I was assuming everything was 3/16" line with 3/8 24 fittings? Thanks!
                  its all 3/16" lines. I've always recycled the original fittings because of the goofy sizes.
                    When I got tired of failing stock combination valves, I tried all new replacements from Speedway Motors. Starting with my stock master cylinder and stock brakes, I ended up adding:
                    Front brake holdoff valve (has 2 outlets, so no T fitting needed)
                    Rear brake residual pressure valve
                    Rear brake adjustable proportioning valve
                    I didn't end up driving the car a lot afterward, but from what I remember, it braked better than when the stock combination valve was still working, and heaps better than experiments using incorrect hardware (i. e. just a T fitting to the front and adjustable prop valve to the rear drums).
                    Speedway lists their holdoff valve as being for disc/drum setups specifically. Perhaps disc/disc doesn't need a holdoff valve because the concept is to help overcome the return spring on the drum brakes? Anywhoo, what I think I remember reading was that disc/drum cars use a 10psi residual pressure valve, and disc/disc use either 2psi or no residual pressure valve. Thain may even remember that conversation, even though it was aeons ago.
                    Edit: Found my post from fully a decade ago! Seems I found info from a website called The Brake Man. I don't see tech info offhand on their new site, but I mentioned a few things here at the time:
                    http://www.grandmarq.net/vb/showthre...l=1#post548593
                      THanks! That's good info. I'm living with "decent" braking now, it stops the wagon well and holds the rear brakes well enough for my 2 step at the drag strip. Would like better holding power though!
                        get the air out.
                        i have 98 front brakes and 93 rear brakes on my 86 town car and i never changed anything else.
                        works fine.
                        car has been all over the east coast several times.
