MegaSquirtPNP Gen 2 in a box...
    I’ve read through a few build threads here on grandmarq.net & have seen a few people use the megasquirt system.
    Here's the system I'm talking about: http://www.megasquirtpnp.com/docs/ms....php?isModel=1
    My question is: will it play nice with a 87 MPFI lopo box wagon harness?
    I know its designed to be plug n play for a fox body MPFI... however my logic is that since so many users run fox body HO swaps with the factory box harness; I would assume you can do the same for the MSPNP on a box harness.
    Am I wrong in thinking this? Anybody actually run this set up without having to tear into the harness?
    If the megasuirt really is PNP on a box harness that would be great to say the least.
    Full MAF swap used AP9 is upwards of $500+ (holy shit) and my planned mods are eventually going to require a tune so spending the $800 on MS PNP makes sense for my build.
    Any discussion is appreciated my mangs.
    All the best, Kyle.
    1987 slick top Wagon
    Search "photobucket embed fix" to remove watermark from photos
    You would have to reprogram the firing order for the injectors and flow rate, but I think that's about it for it to work with a lopo. I think that's the only difference between lopo and HO speed density.
      Hey Sly. To clarify I would be running a HO firing order camshaft with gt40 style intake. I would not run the MS on the lopo long block... When I mentioned lopo above I was referring specifically to the factory harness. Would that still require changes?
        If you repin the ecm connector for a fox body (and have HO firing order via camshaft) then there is no reason it shouldn't work that I can think of.
          This. If you're running speed density tune... no issues. Mass air of course will need that sensor added, but that's it.
            Hmmm I'm gonna have to dig into the archives and figure out what pins need to be moved at the PCM connector... I may just end up going with the tried & true MAF swap after all. Might post a wanted ad here soon for the AP9 computer and associated parts.
            I finally got a decent 3 bar GT40 explorer motor... Well Actually I got the entire explorer lol. It was $800 and the engine runs great. I put 120 miles on it today driving it home.
            It's got great pull even with the horrendous exhaust manifolds they put on these explorers.
            Here's a quick video I took of it, idles smooth:
            It's gonna be great having this motor in the wagon. The old lopo is just tired and this motor just feels wayyy more powerful even unmodified. I was told the explorer cam sucks but honestly it pulls pretty decent.
              It should be the same wires to do a MAF conversion. The injector pins do not move. There are a couple pins that currently go to smog control solenoids that move, the MAF goes to those pins. Add the VSS and fuel pump monitor (if you care about that one) and you're done. Its like 6 wires total.
                Wow that doesn't seem so bad. I found a few old threads that have the pins that need to be moved around... Matter fact I think your the one who posted them Gadget lol.
                I'll keep yall updated if I run this Megasquirt PNP set up. I'm currently getting all the hardware accumulated for the GT40 swap right now... so the work will start sometime in the near future.
                  I converted mine years ago and its been fine, but the sad fact is the computers are getting harder to find and the prices are getting stupider. Much as I don't really like aftermarket stuff because of its spotty reliability, the factory stuff is old to the point where its also getting less reliable.
                  further reading implies it doesn't even need a mass air sensor, so it saves that. Shame it doesn't use the stock MAP sensor, that would be an even cleaner install. The fact that it runs only one O2 sensor makes me think its batch fire rather than sequential. Also a negative in my mind.
